Old 07-03-2011, 09:21 AM   #1
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
another alternator bites the dust
Went to my moms and dads house friday evening and my car was making a winding noise like a wheel bearing or loud super charger. I thought it was a wheel bearing at first but the noise got louder with reving the engine so i figured alt or water pump. Took belt off and alternator off yesterday and its hard to spin the pulley so the bearing is bad and the regulator is stuck cause its up to 14.10 volts instead of the normal 13.8 My car has 60,000 on it. Dealer wanted 590 for the alternator No one carries these things either
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 07-03-2011, 01:14 PM   #2
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
http://www.yarisworld.com/forums/showthread.php?t=35309
smoke search
MickZEL is offline   Reply With Quote
Old 07-06-2011, 05:13 PM   #3
ecc_33
ecc_33's Avatar
Got a life time warranted auto zone alternator today. Figured i would run by the starter alternator guy this afternoon to see if he could fix my old one as a spare. He sayed my stator went out. Sayed he has NEVER seen a yaris, echo alternator ever go bad. There were no parts aval. to fix it. And he could get a bosch reman for 199 life time warranty of course. So i guess this isn't a common thing cause the dealer said the same thing
Old 07-06-2011, 09:43 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
Most electronic parts such as starters and altenators for toyota are all made by denso which is a really good quality part. Lot better than bosch and some of the other manufactures. Which is also why they typically cost more even for a remand. You say the voltage is at 14.1 which is no indicator that the altenator is bad. Most cars range from high 13.5-14.0 Also when you rotate the pulley for the altenator there is going to be a slight resistance its not going to spin like a idler pulley. Actually its more likely a idler pulley would go bad first. What i would do is with the belt removed start the car and see if the sound is gone 100 percent then you know for sure its an accessorie thats causing your sound.
Old 07-07-2011, 05:37 PM   #5
ecc_33
ecc_33's Avatar
No, the old alternator went from charging day in and day out 13.80v to 14.2+ volts when the noise came. 100% sure it was the alternator bearing. I then took it to a electric motor/alternator repair shop and he said the stator went bad. With the new alternator on the car is back to normal, sound and volt out put
Old 07-06-2011, 10:55 PM   #6
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
Mite went bad to a lot of them have
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
What do you guys use to clean dust? JerseyJeff84 DIY / Maintenance / Service 13 03-30-2011 12:37 AM
Dust sucked in everywhere! Dylan DIY / Maintenance / Service 2 10-25-2010 01:10 PM
WTB:OEM rear shock dust covers with bumpstops DeathBeard Willing to Buy by private party 0 09-02-2010 11:16 AM
set in cement dust centrysis Wash, Wax, Detailing, Exterior Repairs 6 07-01-2010 06:45 PM
EBC Rotors/PADS CorSport CorSport 0 07-10-2009 06:30 PM
