Old 02-04-2014, 02:46 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Unhappy Water in engine bay !
Hey guys.
I washed my car this weekend. When I started the engine so that I could move it back into the garage, I heard a belt squeal. I opened up the hood to see water in there !! all over the fuse boxes on the left and right sides !!
The belt squeel was caused by water dripping onto the pulleys .
Am I missing some seals somewhere ? Why is water getting into there ??
See the attached photos.
JudgeM is offline   Reply With Quote
Old 02-04-2014, 03:11 AM   #2
Water getting in is completely normal. When you drive while it's raining, water can splash up from underneath as well. However, belt squeak is not normal. I don't think water caused it. Check your belt to see if it's aged. Might need to replace it, or adjust the alternator. My guess for that is it needs to be moved to put more tension on the belt. However, I'd rather just replace the belt at that point.
Old 02-04-2014, 03:36 AM   #3
bairjo
Garm sells a rubber seal kit for the front and side under hood area. Most cars come with one but the Yaris didn't. I purchased one and it does make a difference. It is pre cut ready to stick in place. I think there was a thread at one time showing this.
Here is the link...
http://shop.microimageonline.com/Hoo...is-hs-ys-1.htm
Old 02-04-2014, 03:47 AM   #4
JudgeM
JudgeM's Avatar
I am pretty sure this water is not from under the car. This is from the top. It seems to be coming through the headlight area.
I am pretty sure the belt squeal is from the water, I saw the water had gone down onto the pulleys and belt as well.
bairjo, the link you posted :
"Hood Seal - Yaris. Comes with peel-off adhesive, one piece 2m (6 feet) length. This is "P" type weatherstripping very difficult to find here. We import this product from New Zealand."
I am in New Zealand. lol this should be easy to find here !
Old 02-04-2014, 01:08 PM   #5
Oh, I'm just saying that water can also get in from the bottom, so it shouldn't be the cause of a squeaky belt. Washing the car will make water come in from any of the gaps from the hood.
Old 02-04-2014, 08:12 AM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
i am convinced water is not the cause of the belt squeal.
Water do get in the engine bay from all sides, that's why connectors are sealed and fuse boxes are covered.
Old 02-05-2014, 01:28 AM   #7
JudgeM
JudgeM's Avatar
I just find this so odd. In all the cars I have owned and washed them. Never had water going into the engine bay.
I will look at the domestic market ones here and see if they have any additional insulation. It rarely rains very heavily here so i may not bother with additional insulation for now
Old 02-05-2014, 04:11 AM   #8
lamadoo
Drives: 2007 Yaris 3door white
Man if your using one of those self car wash be careful. Don't use the high pressure gurni and place it close while washing your car, keep it at a far distance. If there's clear coat spray from the self-wash avoid it as well.
I did this and water would flood the engine bay area SOO much more than yours. I had problems with electronic lock/unlock, Throttle position sensor and engine stalling with engine light on. All fixed now as I wash my car with care
Even if the Yaris is quite water resistant, I don't dare say its waterproof. Try resetting the fuse box by taking the ecm out for 5 secs and putting it back on again
lamadoo is offline   Reply With Quote
Old 02-05-2014, 08:24 AM   #9
IllusionX
weird... rain water just flows in the engine bay all the time. no issues. And i can tell alot of water gets on the accessory belt, cuz it splashes on the hood.
engine bay, washing car, water
Post your engine bay pics! eTiMaGo Photo-Video-Media Gallery 145 04-27-2015 09:50 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Engine Bay Short Shifter gsf1200m Items for Sale by private party 0 03-23-2011 08:47 AM
Engine Bay Clean Up CAyaris DIY / Maintenance / Service 3 03-21-2011 09:29 PM
FS: NST short shifter (engine bay) thebarber Items for Sale by private party 6 01-29-2010 11:39 AM
