Old 04-05-2014, 05:16 PM   #1
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Brake symbol turns off delayed after engine start
Hi,
I recently noticed the brake symbol turning off with a short delay when I start the engine.
It's about 1...2 seconds, but no longer than PS, ABS etc. stay on.
Is there an issue about to come or can I let my diag interface stay where it is?
dj92 is offline   Reply With Quote
Old 04-05-2014, 06:03 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Brake symbol should turn on and off with your handbrake.
Old 04-05-2014, 07:57 PM   #3
dj92
Embracing Curves
dj92's Avatar
So it does of course ;)
However, I wondered why it was on while the brake wasn't engaged
Old 04-05-2014, 07:32 PM   #4
On Yaris with ABS, the brake light is an indicator for the ebrake as well as a secondary warning light for the ABS. I found this out experimenting with clusters. If you install an ABS equipped cluster in a non-ABS Yaris the brake light stays on.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
Engine Slow to Start ruimond DIY / Maintenance / Service 26 04-24-2021 02:37 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Engine dress up - brake fluid resivoire cap? YarisSedan Cosmetic Modifications (Exterior/Interior) 5 11-15-2008 07:59 AM
