Old 10-25-2014, 01:36 PM   #1
spookybathtub
Drives: 2007 Yaris HB
Grill near map light
What is the purpose of this grill near the map lights in the ceiling? I have a 2007 hatchback. I'm installing an aftermarket stereo with Bluetooth, and I was thinking this would be the best place for the microphone. But curiously these slots are solid, and they don't seem to be easy punch-outs.
spookybathtub is offline   Reply With Quote
Old 10-25-2014, 02:18 PM   #2
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
No idea. Though the plastic inside is pretty thin. I carve it using box cutter and installed an LED as ambient light. (Ran a wire through the A-pillar down into the main fuse box)
Mittelklasse is offline   Reply With Quote
Old 10-27-2014, 05:54 PM   #3
jcboy
Drives: Sedan 07
This is who i got my idea from, together with CTScott's sunroof switch. I cut the holes out too, created an LED circuit with resistor on a small PCB, then put a nice heater icon that lights up with the parklights. I ran the wires by the driver side A pillar too.
Old 10-26-2014, 10:07 PM   #4
sheekeebut
Minimalist
Drives: 07 silver sedan
Cooling/venting grill, I imagine. Bulbs can get hot if left on for a while. Those holes are better than nothing. The mic would be tough to fit in there, and would be useless on a rainy day.
If you're considering a place to put the mic, but stealthy, why not buy an extra driver's side instrument panel finishing trim (that triangular-ish piece on both sides of the stereo) and fashion a cool hole pattern, behind which you can install the mic? The best part would be that it's right next to the stereo head unit, so less fumbling with routing wires.
sheekeebut is offline   Reply With Quote
Old 10-26-2014, 11:06 PM   #5
spookybathtub
I highly doubt it's for cooling, since the holes don't go all the way through, and heat rises. Good point about the rain noise, but that doesn't really affect me living in Los Angeles. I think that panel you mention might be too far from the drivers mouth? I think the closest spot would be on the visor, but it would be too conspicuous.
Old 10-26-2014, 11:49 PM   #6
sheekeebut
Minimalist
You're totally right about it not for cooling. Though I am a bit curious about it. It should have a purpose, but the thing looks closed solid there. It might still knock out properly if one has the right tools, or perhaps it's just a common moulding for the plastic. That said, it may very well be for a speakerphone mic of some sort.
Old 10-27-2014, 01:13 AM   #7
sheekeebut
Minimalist
You can probably cram a little mic in there, but some cutting is involved. Based on distance to your mouth, I'm sure it'll work just as well as above the gauge cluster or on the steering column.
Old 10-27-2014, 02:34 PM   #8
Pokey
Drives: 2010 4 Door Hatch 5 Speed
I cut open the slots with a Dremel, and put the mic for my Bluetooth in behind. Hot glued it in. Works great from that position
Pokey is offline   Reply With Quote
Old 10-27-2014, 03:27 PM   #9
From another thread
Originally Posted by RETRO View Post
They are slots for cars that are equipped with Bluetooth..So Toyota has them in all their cars.. My wifes Corolla equipped with BT has them my Tundra is equipped with BT as it too. My yaris does not have BT but has the slots for them.
2012 Yaris LE Check Engine Light On/Eco Light Off 2012YarisLE DIY / Maintenance / Service 1 01-22-2014 12:29 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
Plz help re: LED lights sleey0 DIY / Maintenance / Service 4 07-23-2010 10:55 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 04:41 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 02:46 PM
