10-11-2016, 09:48 PM | #1 |
Drives: White '07 3dr LB Join Date: Jun 2016
Will new muffler help with fuel efficiency ?
The muffler on my 2007 2dr HB is getting pretty rusty, I think the whole exhaust system is stock, so about 10 years of age. I'm planning on giving it at least a new muffler in the spring, and I'm wondering if an aging muffler does any significant loss in mileage ? It's not perforated or falling appart yet tho, just very rusty.
10-11-2016, 10:41 PM | #2 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
banana in the tail pipe...
10-13-2016, 06:50 PM | #3 |
Drives: Yaris Sedan 5MT Join Date: Oct 2008
No, buy a new right foot instead.
Buy your muffler based on the sound you want, otherwise just do oem.
10-15-2016, 10:58 AM | #4 | |
Drives: NONE Join Date: Oct 2008
10-15-2016, 01:53 PM | #5 |
Drives: 2007 2-door hatchback Join Date: Jul 2016
Scraping off the loose rust and scale rust and debris on top of the muffler will extend life, as all that holds water and salt.
10-15-2016, 07:26 PM | #6 |
I also have that clinging noise that I remember someone mentioned was caused by a loose piece of sheet metal banging against the manifold or exhaust pipes around the back of the engine bay, that would be the next fix I want to do. Anyone has a clue on the most probable location of the loose sheet metal part ?
10-15-2016, 10:20 PM | #7 | |
Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
Clanging could also be caused by a worn out gasket between the manifold and the down pipe. If your '07 is still on original gasket, then it is probably shot.
10-16-2016, 09:58 AM | #8 | |
Similar Threads | ||||
The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Change to high quality filter lead to drastic drop in fuel efficiency | lh59 | DIY / Maintenance / Service | 19 | 07-02-2009 02:22 PM |
