![]() Drives: 2012 Yaris Join Date: Apr 2017
2012 Yaris L - Aux/USB input?
Just curious if the base Yaris L has the Aux/USB input in the glovebox?
![]() I'm about to drive pick up a 2012 Yaris L and drive it 12 hours home....just trying to plan ahead. I'm already going to install the cruise control. Thanks!
Hmm, I see...
Drives: 2012 Toyota Tundra and Yaris Join Date: Oct 2016
mine does, and its about as base as you can get (manual transmission and windows)
"Everything happens for a reason. Sometimes that reason is you're and idiot"
![]() ![]() ![]() Drives: 2014 Yaris Join Date: Feb 2017
Mine is a 2014 LE and I moved the USB/aux input from the glovebox to the center console by the hand brake. I understand the idea behind putting it there, but I hated it there. So I moved it. Sent from my iPhone using Tapatalk |
#5 | |
#6 | |
It was a pain to move it, so heads up. Remove the glovebox, the passenger side dash cover, the stereo head unit, climate control panel with knobs, and center console, then pop out the USB connector, set it aside, separate its wires from that portion of the wiring harness (careful, there are airbag wires in there) and route them back and down behind the head unit and climate controls area, and under the center console along the shifter mechanism. The square USB connector fits right in those blank square pieces by the hand brake. The wires are JUST barely long enough to reach there when you separate them from the wiring harness. Once everything is set in place, I recommend you tie the harness back up so the wires aren't just dangling around. Sent from my iPhone using Tapatalk |
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
My wife has a 2012 L. It has the auxiliary input and USB in the glove box and her's didn't even come with Bluetooth lol
-Karl the Uber/Lyft Driver |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| 2007 yaris snow tires on 2012 | lomky | Third Gen Yaris General Discussion | 4 | 11-16-2012 03:00 AM |
| European Yaris TS 2012? | Jochen | Third Gen Yaris General Discussion | 17 | 04-19-2011 01:43 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
