06-09-2021, 07:32 AM | #1 |
Drives: toyota yaris RS Join Date: Jun 2021
Knock when warmed up...
Hi guys i have began noticing a faint knocking when my car is fully warmed up, this happens only when car is idling.. it idles quite low @ 600rpm. Plugs are new, pcv, vvt solenoid..oil fully synthetic mobil1 5-30 .. the car is an RS 2011 with only 71 000kms..
Anyone .. |
06-09-2021, 07:46 AM | #2 |
Drives: No longer own a yaris :( Join Date: Mar 2012
Make sure it is actually the engine. My bottom alternator bolt had worked itself slightly loose once and the slight movement of the alt on the bracket sounding exactly like a knocking engine at idle.
I'm a hermit named Lee |
06-09-2021, 12:28 PM | #3 |
i did the test removed the serpentine still that faint background knock... but when the hood is closed you dont hear it... i filled up with very high octane booster and it started this...
Similar Threads | ||||
Alternative to Rod Knock?! | atomic_hoji | DIY / Maintenance / Service | 18 | 03-19-2019 07:27 PM |
Poor gear shifting, Knock sensor code and poor idle running at cold temperature | Olusegun25 | General Yaris / Vitz Discussion | 2 | 06-20-2016 11:53 AM |
Toyota Yaris Hybrid 2015 Knock Sensor | imz | General Yaris / Vitz Discussion | 0 | 06-11-2016 08:43 AM |
Rod knock or Main bearing knock? | jabranko | General Yaris / Vitz Discussion | 27 | 08-05-2011 11:14 AM |
reg or mid | dg4rez | Fuel Economy Forum | 18 | 11-24-2008 02:13 PM |
