![]() Drives: 2007 toyota yaris sedan Join Date: Jun 2015
Driver Side Rear Door Glass (Help Please)
Has anyone had experience replacing the door glass on the rear door of a Yaris Sedan? I'm looking to save some money by replacing a broken window myself instead of taking it to the shop. However after removing the interior plastic door panel and getting everything else out of the way, I can't see or figure how to detach glass from the window regulator parts? I've replaced the driver side glass once before and in that situation the glass was bolted to the window regulator. Obviously it could be unscrewed and then taken out of the door after getting it out of the tracks. Here not the case, it's like stamped onto the regulator. I'm wondering how a shop would even go about doing it if I took it there?
2ZR swap. DO IT! Ask how!
I'm trying to think back to when I pulled the doors from the junk yard and I'm drawing a blank. Looking at the manual, it shows 4 bolts on the regulator for power windows, 3 for manual. There's no fasteners between the arm and the rail at the bottom of the glass, so it probably just slides off. There's a screw hidden at the top of the vertical rail between the window and the corner glass if you need to remove that rail.
Drives: audi Join Date: Nov 2022
You can check the manuals thoroughly however the shopkeepers have experienced and trained staff to do this work perfectly.
Drives: ford Join Date: Dec 2022
My wife owns the yaris and we got it replaced from local dealer at very affordable prices.
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
this forum is broken. I can't upload .htm or .rar files
I think I linked the service manual a long time ago. You might find it by search function |
Drives: bmw Join Date: Dec 2022
It was very annoying work for me when one of my friend told me that I can do it at home. I started doing it and left in the middle. I had to visit the local shop for fixing the rear door glass and they did it very nicely.
| TRD Delrin Rear Axle Bushing Collars | tmontague | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 12-15-2019 08:50 PM |
| water collecting in driver side rear footwell | AmberNShakey | DIY / Maintenance / Service | 1 | 01-20-2014 04:48 PM |
| Driver Side Wiper Issue | justfillingtime | DIY / Maintenance / Service | 2 | 02-15-2013 09:08 AM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
