![]() Drives: Yaris 2014 Join Date: Aug 2014
Only with bolt ons
And that’s with the factory cat. The high-flow one is coming soon.
I forgot to mention that that was the result after the reflash.
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
If you don't do the reflash, would cold starts have high rev similar to changing the throttle body with one from the 1ZZ?
A reflash won't change your cold-start idle speed; you need to adjust the Allen-head screw on the throttle body—the one with the locking compound on it—to fix that. I adjusted mine with the A/C on so that when the compressor kicks in, the RPMs don't drop too low and cause the engine to stall or start shaking. Before the adjustment, it would rev to 3,000 RPM or higher on a cold start; after adjusting it, it goes up to between 1,900 and 2,100 RPM, depending on the ambient temperature. I’ve tested this with both the 1ZZ and 2ZR throttle bodies.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Whiteline Control Arm Bushing install and Review | tmontague | Performance Modifications | 3 | 06-08-2019 02:42 AM |
| Aftermarket bolt ons vs OEM dispute | tmontague | Off-topic / Other Cars / Everything else Discussions | 17 | 04-02-2017 11:37 PM |
| Broken Control Arm Bolt | Sirius-XM | DIY / Maintenance / Service | 4 | 02-29-2016 08:27 PM |
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 03:18 PM |
