![]() Drives: 3D LiftBack White Join Date: May 2007
Shocks & springs
Do I have to change both at the same time if I want to lower my yaris?
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
Not really. Though it's advised. I've decided to wait to install my springs until I get new shocks. You can ride on shorter springs but it will greatly reduce your shocks life span. :) So I've heard.
Tantum religio potuit suadere malorum. |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
Tanabe stuff was tuned to work with stock. They will be fine and will last a very long time. If you want a truly sportier ride you would want to replace you struts or get coilovers. In my opinion.
SPONSORED BY
![]() ![]() Drives: Toyota Yaris Hatchback Join Date: Jun 2006
Also keep in mind unless you are doing the install yourself most places will charge you the same amount for just struts, just springs, or both at the same time.
Watching a movie about street racing DOES NOT MAKE YOU A TUNER!!! |
True. Even if you're doing it yourself, do you want to do it twice? :)
![]() Drives: Bayou blue auto hatch Join Date: Mar 2007
Hey guys,
I just did the install of Teins. Nice spring with a decent drop. I've found that significantly increased spring rates, struts and whatever, make a ride teeth rattling. I think the boys figured this out for us, mild street tunner vs. way serious, with little in between. By the way, the install would go a lot faster with an impact wrench. Without it it's a struggle. |
#7 | |
Parallel Parking Pro
Lowering springs reputedly reduce shock lifespan and there are sound reasons why this is so, but it has been much exaggerated. If you simply cut your springs, yes, this would be the case, because you'll start bottoming out and riding on your bump stops too much, eventually breaking it. But with a proper set of lowering springs, the spring rate is increased to compensate for the reduced shock travel, and avoid bottoming. So I figured I'd do the springs first, while waiting for Koni to roll out their replacement shock inserts for the Yaris. I hope that by the time the factory shockies start feeling tired it would be the right time to complete the suspension upgrade with adjustable Koni inserts.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#8 | |
Getting a jack under the car after you lower it is the real problem lol.
Ya I did mine like last July in the heat. What is everyone using for struts and shocks when they are changing them????
track or die
Drives: Yaris LB CE CDM Join Date: Jun 2007
do you have to do any cuttings on the OEM parts to install tein basic coilover on a yaris ?
thanks P |
#11 | |
Lonesome Cowboy
SPONSORED BY
#12 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
track or die
#14 | |
Lonesome Cowboy
I didn't have the patience to wait for strut options and Tein Basics offers a little more drop than the drop spring only options out there and I like that as far as looks go. Eveyone that has purchased the basics has given me positive reviews. I hope to have mine installed tomorrow.
SPONSORED BY
Yaris 07 PW LB
Hmm saw them on ebay... look good...
| New Yaris ! | Yarisagos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 03-04-2007 11:35 PM |
| Is it practical to install stiffer shocks without also installing lowering springs? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 01-18-2007 01:23 PM |
| Shocks and springs Q | grimez | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-19-2006 08:48 AM |
| TRD lowering springs' and/or shocks' Ride Quality?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-29-2006 12:42 PM |
