Old 07-03-2007, 02:28 PM   #1
andylai2k
Drives: 3D LiftBack White
Shocks & springs
Do I have to change both at the same time if I want to lower my yaris?
andylai2k is offline   Reply With Quote
Old 07-03-2007, 02:42 PM   #2
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
Not really. Though it's advised. I've decided to wait to install my springs until I get new shocks. You can ride on shorter springs but it will greatly reduce your shocks life span. :) So I've heard.
Old 07-03-2007, 02:59 PM   #3
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Tanabe stuff was tuned to work with stock. They will be fine and will last a very long time. If you want a truly sportier ride you would want to replace you struts or get coilovers. In my opinion.
SPONSORED BY
Old 07-03-2007, 09:34 PM   #4
tmyers82
Drives: Toyota Yaris Hatchback
Also keep in mind unless you are doing the install yourself most places will charge you the same amount for just struts, just springs, or both at the same time.
Watching a movie about street racing DOES NOT MAKE YOU A TUNER!!!
tmyers82 is offline   Reply With Quote
Old 07-04-2007, 01:35 PM   #5
staticorex
staticorex's Avatar
True. Even if you're doing it yourself, do you want to do it twice? :)
Old 07-05-2007, 08:01 PM   #6
doxns
Drives: Bayou blue auto hatch
Hey guys,
I just did the install of Teins. Nice spring with a decent drop. I've found that significantly increased spring rates, struts and whatever, make a ride teeth rattling. I think the boys figured this out for us, mild street tunner vs. way serious, with little in between. By the way, the install would go a lot faster with an impact wrench. Without it it's a struggle.
doxns is offline   Reply With Quote
Old 07-05-2007, 08:15 PM   #7
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
How I approach this is simple. Shocks take typically probably 40,000 miles/60,000kms to expire. I wouldn't want to wait that long to enjoy my car with lowered springs I like the way it handles and the way it looks. Ok, so I'm impatient......
Lowering springs reputedly reduce shock lifespan and there are sound reasons why this is so, but it has been much exaggerated. If you simply cut your springs, yes, this would be the case, because you'll start bottoming out and riding on your bump stops too much, eventually breaking it. But with a proper set of lowering springs, the spring rate is increased to compensate for the reduced shock travel, and avoid bottoming.
So I figured I'd do the springs first, while waiting for Koni to roll out their replacement shock inserts for the Yaris. I hope that by the time the factory shockies start feeling tired it would be the right time to complete the suspension upgrade with adjustable Koni inserts.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 07-05-2007, 08:41 PM   #8
Motorhead6T5
Motorhead6T5's Avatar
Drives: 07 NCP96
Its not very hard,I did mine by myself in my driveway in 105* heat. The front is the pain,and if you use a air rachet on the compressors its really not bad.
Getting a jack under the car after you lower it is the real problem lol.
Motorhead6T5 is offline   Reply With Quote
Old 07-05-2007, 08:44 PM   #9
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Ya I did mine like last July in the heat. What is everyone using for struts and shocks when they are changing them????
Old 07-05-2007, 11:12 PM   #10
dsc_pat
track or die
Drives: Yaris LB CE CDM
do you have to do any cuttings on the OEM parts to install tein basic coilover on a yaris ?
thanks
P
dsc_pat is offline   Reply With Quote
Old 07-06-2007, 10:09 AM   #11
brickhardmeat
Lonesome Cowboy
thanks
P
just the bump stops and dust covers
SPONSORED BY
Old 07-06-2007, 10:42 AM   #12
kurokoma-kun
Drives: 2007 Yaris HB
Drive it up onto a board or flat rock first. That's what I have to do with Miata, it's too low for floor jack stock!
my yaris, kurokoma-kun
Old 07-06-2007, 07:58 PM   #13
dsc_pat
track or die
thanks
another good reason to get them
i wish Koni would hurry up
Old 07-06-2007, 08:17 PM   #14
brickhardmeat
Lonesome Cowboy
thanks
yeah, I'd go with Tein basics, wait I did
I didn't have the patience to wait for strut options and Tein Basics offers a little more drop than the drop spring only options out there and I like that as far as looks go. Eveyone that has purchased the basics has given me positive reviews. I hope to have mine installed tomorrow.
SPONSORED BY
Old 07-07-2007, 02:48 AM   #15
Jerzidude
Yaris 07 PW LB
Jerzidude's Avatar
Drives: Yaris 07 PW LB
Hmm saw them on ebay... look good...
Jerzidude is offline   Reply With Quote
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
New Yaris ! Yarisagos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-04-2007 11:35 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
Shocks and springs Q grimez Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-19-2006 08:48 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
