Old 07-22-2007, 12:25 AM   #1
flighttekchris
flighttekchris's Avatar
Drives: 2007 Yaris 3door
17X7 wheels
ok I'm confused, i am looking at a set of Urban Racing 17X7 Type 8 wheels, with 205-40-17 tires, will this fit my LB without rubbing?
can anyone help me with this?
flighttekchris is offline   Reply With Quote
Old 07-22-2007, 12:44 AM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Yup, that's what I have. Just sure the bolt pattern is 4x100 and the offset is anywhere from 38mm to 45mm (40-42mm is best).
PetersRedYaris is offline   Reply With Quote
Old 07-23-2007, 04:31 AM   #3
Chaser
Drives: Yaris E A/T 2007
I think it will not rub.. do not more than +38 offset
Chaser is offline   Reply With Quote
Old 07-23-2007, 04:35 AM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
as peter said 40-42 is the best +45 in the front and +38 in the back would be pretty phat with 205/40's all the way around
Old 07-23-2007, 08:56 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Ditto.
Depending on the tire, ET38 may poke out a bit up front, ET40-42 would be much better, and ET45 would give you a tiny tuck up front which usually looks best and eliminates most rubbing problems.
If you're not lowered, go with 205/45's. If you're lowered, you may want to go with 205/40's, especially if you run ET38's.
However, you could manage 205/45's if you're lowered and you have chosen the proper offset.
Old 07-23-2007, 09:11 AM   #6
flighttekchris
Originally Posted by kimona54 View Post
Ditto.
ia am looking at the +40 as an offset, as i have no plans on lowering the car from stock,
PetersRedYaris can you post some pictures of you tires so i can see how they fit? what offset do you have?
BTY i am new to this.... what is "offset" anyway?
thanks
chris
Old 07-23-2007, 02:09 PM   #7
Black Yaris
der Zeck
Damn you EchoHrs Damn you... stop posting that incredibly hot ass picture of your ride...... I think the US needs to invade Canada so we can aquire the 5DR RS Yaris... why not? We invaded Iraq for WMD that were not even there, at least we would get the RS out of Canada :)
Old 07-24-2007, 12:39 AM   #8
PetersRedYaris
Look here-
http://www.yarisworld.com/forums/fun...do=view&id=153
I have Tanabe NF210 springs for a drop of 1.1 in the front and 1.3 in the rear. My tires are 205/40/17 and wheels are 17x7 with 38mm offset. Remember, the lower the offset, the furthur OUT it places your wheels. So, I am as wide as is recommended (as seen in the close-up of the front wheel). I have never rubbed, probably due to the slightly smaller tire diameter.
Good luck.
Old 07-24-2007, 05:08 AM   #9
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Does anyone know the stock wheels offset? I looked at rims and asked what the offset is and they said factory......
slvryaris is offline   Reply With Quote
Old 07-25-2007, 07:29 PM   #10
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
Originally Posted by PetersRedYaris View Post
Look here-
Good luck.
That's quite the lunch box you have there up on your roof.
How's the ride with that thing? I'm assuming there is wind noise but any vibrations or the like?
Looks good and thanks for the all info. Just because WE all don't ask the questions doesn't mean WE all can't learn from YOUR answer.
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 09:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 07:55 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 07:01 PM
Enkei RZ5 wheels on Liftback kennywhy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2006 05:22 AM
