#55 |
rice rocket
Drives: 05 Echo Join Date: Feb 2007
the DRL uses the low-beam for us. You can confirm this by turning on/off your headlights at night near a wall where you can see the change is just the brightness when the headlights are turned on.
i should add, this is for my echo, which should not be different from the yaris but it might. The same method to check still applies. |
#56 |
Well I would think its a no brainer for it to be a lower voltage off the LOW beam, beacuse although its a lower voltage, the beam PATTERN would be aim'd up if using the HIGH beam portion of the H4?
Violin may be able to shed a little more light here.. |
#57 |
I want JDM bumpers!
Drives: 5 Dr Yaris RS in Blazing Blue Join Date: Feb 2006
I just checked the wire diagram for the Yaris, and it seems that taKuto is correct, the Yaris uses the Low Beam filament as DRL... which creates a bit of a problem. If I'm using the H4 common wire as the trigger for the HID, will this common wire be on when the car is supposed to be running on DRL? I can't seem to understand the diagram from Violin, as in the H4 plug, the H terminal is not linked to anywhere? GuySmily's diagram seems to be much simplier with just one relay?
#58 |
Well then, if you are expecting to keep the DRL box hooked up in your car, and splice off the regular plug to fire your HID's, it wont work. Keeping DRLs and having HID, will "strobe effect" your ballasts, and kill them over time.
Hence the reason for disconnecting the DRL box for anyone installing just a plug-n-play in their Yaris. |
#59 |
I don't really have a solution to your DRL dilemma. Would it be legal to have a separate pair of lights, perhaps behind the grill, that come on whenever the ignition is switched on? That would be simple.
In my diagram, the car side H4 plug plugs into a female H4 plug that I purchased and integrated into the harness. See my DIY for parts suppliers. |
#60 |
rice rocket
You will only need one relay, and diodes for the low beam and high beam triggers which connect to the relay. You cannot use GuySmiley's harness since that's for positive trigger. You will need a negative triggered harness made. Wish I had the time to make you the schematic, but I'm sure you can find it somewhere.
#61 |
der Zeck
dumb question.... but since we have city lights in the LB, could you just use those as you DRL? or can you hook up the high beam bulb on the same circute as the parking lights and use relays in a series to have them shut off when the lowbeam HID's come on..... only down fall to this will be no regular Highbeams at night
I can draw up a scamatic if you do not understand... but it will work, and you can keep your DRL disabled and run HID's :)
#62 | |
I want JDM bumpers!
#63 |
rice rocket
positive trigger = a +12V wire is given power when the switch is on.
negative trigger = the ground wire is active when the switch is on. toyotas are mostly negative triggered. Makes the harness a little different for constructing. The high beam will get the common 12V and the high beam ground The low beam (HID) will use a relay harness which will use the low beam and high beam grounds as a trigger wire. Black Yaris, what are city lights? Do you mean the parking light? Is it a bulb that turns on when you flip the headlight switch one notch, and stays on during the low-beam switch? |
#64 | |
der Zeck
what you are calling a negative trigger is called a pos(+) ground City lights are the these, I had this pic laying around, to explain city lights to someone else
#65 |
The reason I use three relays is so I can flash the high beams without the HIDs coming on. Worth the effort, I think.
#66 |
rice rocket
When is that city light active? I don't have one for my echo so I wouldn't know anything about it.
#67 |
The first position on the light stalk turns it on, the next turns on the headlights. I used it (labled "arking lamp circuit" on my schematic) to trigger the one relay - if I used the low beam, they wouldn't turn off without shutting off the car. If Canadian models lack a city/parking lamp, my harness wouldn't work.
#68 | |
I want JDM bumpers!
#69 |
I want JDM bumpers!
Is it possible to wire the Fog Lights to become DRL? Just a though after talking to my friend. He did a retro fit to his Civic SiR with Audi A6 projector, and he wired his Fog to become DRL with the use of relays... I will ask him for more detail on that.
#70 |
![]() ![]() ![]() Drives: '00 Toyota Celica GTS Turbo Join Date: Aug 2006
GabL I went through a similar dilema with my Celica. i'd just retrofit a custom HID setup for the headlights with some grommets thats what i did and its works like a beauty. Also as someone pointed out that the 3prong is for a leveling switch. Pretty easy to wire up. If you're interested let me know I can teach you how to hook it up. It does wonders in the Celica! I might have to do this for the Yaris now. Do you have a link on where to buy these headlights? Additionally do you have more pics of the headlights? Is there no longer any permenant amber on the headlight just in the bulb? Please let me know. Thanks!
#71 | |
I want JDM bumpers!
I'm also interested to know how to wire up that auto leveling switch? Please post some pictures if you can. Thanks! I got the headlights from Taiwan Yahoo auction as mentioned (tw.bid.yahoo.com). It doesn't have the permenant amber reflector at the side, also the side parking light is not on this headlight also. I will try to post some more pics later! |
#72 |
![]() ![]() Drives: Toyota Join Date: Apr 2007
So whatever happened to this project?
| Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) | gaffo | General Yaris / Vitz Discussion | 28 | 07-15-2007 08:55 PM |
| Southeastern Power Package with Alloy wheels? | Where is my Yaris? | New YARIS Purchase Forum | 0 | 03-23-2007 08:40 AM |
| convenience vs. power package | jeff_o | General Yaris / Vitz Discussion | 25 | 10-17-2006 11:04 AM |
| Is concenience package and power package the same thing on liftback ? | YarisBlazer | General Yaris / Vitz Discussion | 4 | 07-22-2006 12:58 AM |
| Waiting for the Taiwan Yaris | heybai | General Yaris / Vitz Discussion | 13 | 03-12-2006 08:26 AM |
