Old 08-10-2007, 08:57 PM   #1
rear spacers [pics]
I got the 10mm rear spacers on today. Here's a couple before/after pics. Subtle, but it really makes a difference from some angles, especially with the kit on there.
Old 08-10-2007, 09:06 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
greatly improved! looks balanced now
SPONSORED BY
Old 08-10-2007, 09:35 PM   #3
nqd
Drives: 07 Yaris LB Absolute RED
is there any other advantage for spacers besides looks?
v
nqd is offline   Reply With Quote
Old 08-10-2007, 09:45 PM   #4
uncleyaris
I like it Cali!!
Old 08-10-2007, 10:05 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Hey cali yaris,
Looks very good! If I recall, you were running 16x7's, ET38 with 195/50/'s.
So now, you're essentially running FR, ET38; and RR, ET28. Is that right?
Did you use hubcentric spacers with longer bolts?
Are you flush all 'round now?
Old 08-10-2007, 10:27 PM   #6
brickhardmeat
Lonesome Cowboy
Ichiba sales pitch...
Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
SPONSORED BY
Old 08-10-2007, 10:30 PM   #7
kimona
kimona's Avatar
Originally Posted by brickhardmeat View Post
christ! another 10mm or a total of 20mm would put you at +18 that is way too much poke, I think you are poking a tad now but with the extra few mm's from the kit it looks just about right
No... I think he's +38 up front and +28 rear (with the new spacers).
Probably flush up front (but very tight...good he went with the 195's).
Like you, I'm curious where that rear rubber sits now... looks about flush in the photos.
Old 08-10-2007, 10:37 PM   #8
brickhardmeat
Lonesome Cowboy
yes, he is but someone suggested he go with another 10 which would be 20 total, I already edited my comment because I didn't want to enter into a discussion over it, right he only used rear spacers, there is no need to touch the front
I'm considering going with 15mm spacers now in the rears
SPONSORED BY
Old 08-11-2007, 12:26 AM   #9
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
if you overkill with spacers, you might need extended lug nuts depending on your wheels, just fyi. but looks good with the 10mm!
reznunt is offline   Reply With Quote
Old 08-11-2007, 01:06 AM   #10
driver centric
I know right?
driver centric's Avatar
Drives: 07 Bayou LB
brick, did they come with extended studs? No way I'd run 10mm with the stock ones.
-Kev
07 Bayou Blue Liftback 5-spd manual
driver centric is offline   Reply With Quote
Old 08-11-2007, 02:16 AM   #11
Black Yaris
der Zeck
Black Yaris's Avatar
6 threads on the stud is all you need to safely install your wheel
Old 08-11-2007, 02:51 AM   #12
*Fluuuuush!*
Old 08-11-2007, 02:55 AM   #13
501
Drives: 07 yaris
i wonder if the hub spacers from an XB will work with the camber shims.
cali- is that what you used for a spacer or just a wheel spacer
'07 blazing blue hatch-TRD shocks-tanabae df210-TRD rear sway bar-koning feathers 16x7-the basics for now
501 is offline   Reply With Quote
Old 08-11-2007, 03:26 AM   #14
brickhardmeat
Lonesome Cowboy
he used H&R spacers www.allsprings.com
Ichiba makes spacers for the yaris also
both kits come with longer bolts, I asked him if he used the longer studs or if he was able to get by with the stock ones but I didn't get an answer
SPONSORED BY
Old 08-11-2007, 03:29 AM   #15
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
Hey Cali..
i thought you were gonna show up at the meet today??...
man, i was hoping to meet you.
well..anyway, i just got back from the meet..it was very cool.
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-11-2007, 10:18 AM   #16
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
im waiting to hear if he used longer studs as well.....
Old 08-11-2007, 12:36 PM   #17
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Glad to see you put the kaminari badges on! The spacers look great also! I'm running a 205/50 with +42 and I'm thinking about doing 5-10mm in the rear.
cm07yaris is offline   Reply With Quote
Old 08-11-2007, 12:42 PM   #18
driver centric
I know right?
Drives: 07 Bayou LB
Right, and how do you know how many threads he has left?
When your wheel flies off at 65 mph, you'll be wishing you didn't skimp and got the longer studs to begin with...if you live, anyway. Why skimp on something cheap and easy to install that provides extra safety?
-Kev
Rear VITZ Emblem & Hatch Opener Painted Polar White. [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 39 05-04-2007 06:20 PM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 04:06 PM
