#19 |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
I THOUGHT I read that for us the smallest is 10 mm
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#20 | |
With 16x7's, ET42, and 205/50's, can you tell us how your set-up fits? It would be a great reference point for those searching for wheels and tires. Are you flush up front or a bit tucked? How about the rear? |
#21 | |
Last night I piled some adults (maybe about 500 lbs total) into the car, and the rear tires rub a TINY bit over extreme dips and such. Acceptable. Any more spacing in the back would not work. The spacers came with 10mm longer studs -- I would think any spacer set would provide appropriate studs also? As for the 'six threads is enough' comment, that's probably worthy of a separate discussion.
#22 |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
thanks for the update, I wouldn't consider going more than 10mm then
SPONSORED BY
#23 |
![]() ![]() ![]() ![]() Drives: 2007 Toyota Yaris Blazing Blue Join Date: May 2007
I am planning on posting pictures of my setup as soon as I get back from vacation and finish the install. I ran into a few mishaps during the past week or so. I received 3 of my 4 rims last week Thursday and the 4th was somehow separated from the rest. I got the 4th one this past Monday only to open it up and see that it had a slightly bent lip and unfortunately they were the last four rims in that color in the US. Long story short, 5Zigen agreed with my supplier to overnight ship a rim from Japan, I am not at home at the moment so I can't confirm this. I received my Megan Springs on Wednesday and got the the rear setup complete with rims, trd struts and shocks, and the megan springs. As soon as I get home I will install the front suspension and new 5Zigen lug nuts. I am just as anxious to get some pics up for everyone's comments, suggestions, and dislikes! Thanks!
#24 |
#25 |
![]() ![]() ![]() Drives: '07 Blazing Blue LB, '09 Jetta Join Date: May 2007
i think i'm gonna need this spacers..just don't kno how thick it would be.
i gotta see caliyaris and show him, maybe he can advice on which size.
current: '07 Yaris LB - '09 VW Jetta ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi Last edited by seanele; 08-12-2007 at 03:53 AM. |
#26 |
Hi!
#27 |
![]() ![]() ![]() Drives: bad boy Join Date: Jun 2007
so where can i order these thru or go to......
#28 |
#29 |
seanele, come by anytime!
#30 |
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package! Join Date: Jun 2006
Hmm...if its pretty much flush with the body kit/fender...will you hit it sometimes going over extreme bumps?? I'm worried about this...since the wheels are currently recessed into the wheel well at the moment...
I'm interested in doing this...i want the 10mm spacers as well..any problems with stock wheel setup? Like everyone else i like the wider stance look...esp. the rear. |
#31 | |
Lonesome Cowboy
SPONSORED BY
#32 |
There is this fine line where the rim is flush, but the tire angles inward just a little bit and you have the perfect match up. I've got mine where I only get rubbing under severe bumps and only with more than one person in the car -- I can live with that.
Also, the rubbing is into the plastic wheel well, not with the metal fender.
#33 |
Toyota Newb!!
Whew...that's good to know!!
I currently have stock wheels..and tires...going to upgrade maybe next summer..i'm doing suspension mods this year... I like the idea of the spacers...and how they made the car have a wider stance...looks a bit better too So i shouldn't have problems with stock 15" wheel and tires right? |
#34 | |
Lonesome Cowboy
SPONSORED BY
#35 |
I forgot, anyone have pic of what offsets look like on the yaris? I forgot is the higher offset makes the wheel come out more or is that the other way around with a negative offset? Im confused now!!!
#36 |
Hi!
the higher the offset, the more the wheels go inward toward the car, the lower the offset (and/or a negative offset), the more the wheels poke out.
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Rear VITZ Emblem & Hatch Opener Painted Polar White. [pics] | Chris07LB | Cosmetic Modifications (Exterior/Interior) | 39 | 05-04-2007 06:20 PM |
| rear fog light and tuned rear lights | lefti696 | Cosmetic Modifications (Exterior/Interior) | 0 | 11-09-2006 04:06 PM |
