High rate springs.
Anyone running higher rate springs? I know Tien comes with 3kg or so, but I'm talking about 8kg.
that'll be coil overs, some (i think the Tein Basics are still in the 3.0kg range). the S.Tech's are 3.0kg in the front and 3.5kg in the rear.
![]() Drives: 07 Yaris 04 TSX Join Date: Aug 2007
Yeah I'm running A lot higher spring rates, but I have coilovers, its 12K in the front and 10K in the rear. The setup is more for the track. I'm using HKS coilovers in the front and Apex in the rear.
Nice setup
I'm running 8K front and 5K rear on my SK RMA8 coilovers, it's a nice balance between daily comfort and great handling on the track. |
Break'em off some.
Werd. Very good looking setup. Those HKS front coilovers look great.
Are those front endlinks available seperately? |
Cusco Compact-S coilovers spring rate is about 7k in the front and 3k in the rear. pretty comfy for daily driving with a bit of hard turning and what not. never tracked it but I want to.
i think i would like 03Z33's set up.
![]() Drives: Yaris Join Date: Jul 2007
Aragosta Suspension
Agarosta can make special order for racing suspension. you can adjust front and rear shock absorber height (not only from the spring). spring rate you can choose from 6K to 18K
and you also can buy options for damping adjuster (2 way or 3 way type) for the 3 way type it's include Sub tank. here is some picture. If you interested, and cannot find it in US. I can get it for you. |
Er, sorry. I ment to say after getting some coil overs. I left out coil overs, cause I'd want something thats a bit stiffer, as far as shocks. But i was wondering if anyone made high kg springs first.
what coilover kit r u using right now? You can buy the universal spring, but you have to make the spring adaptor.
| TANABE SPRINGS | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 11-20-2008 07:38 PM |
| Yaris wheel rate ratio (06+) ? | dsc_pat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 07-05-2007 05:43 PM |
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
| Lowering Springs - Questions ~ AGAIN ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 01-16-2007 12:23 AM |
