Old 08-28-2007, 04:58 PM   #19
CompanyXPaladin
Drives: 08 Yaris 5-speed
Has anyone thought about running a MegaSquirt or a MegaSquirt II in a turbo Yaris?
CompanyXPaladin is offline   Reply With Quote
Old 08-28-2007, 11:47 PM   #20
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
no time no money...
yes, but i have no time, money, or expertise in engine managment ... so i figured my daily driver is a poor place to start...
fu_im_from_texas is offline   Reply With Quote
Old 08-29-2007, 01:43 AM   #21
CompanyXPaladin
Yeah, I hear you on that count. I might swap my FC Commander in my other car out for one just to play with it and see what I can do...
Old 08-29-2007, 09:57 AM   #22
cdydjded
Drives: Yaris LB Turbo
AEM Fuel Ingnition Controler FIC trust me! http://www.aempower.com/ViewCategory...CategoryID=116
cdydjded is offline   Reply With Quote
Old 08-29-2007, 12:04 PM   #23
No harness for that yet, so one would have to be custom made -- not a big deal. I'd like to see how the ECU reacts to it --
Are you going to put one on and try it out?
Old 08-29-2007, 01:10 PM   #24
ChinoCharles
Drives: LB
All talk, no action! cali, we all know you're one of the few real tuners here. Lets see you leap!
Old 08-29-2007, 01:28 PM   #25
LOL - I'm on the edge, looking down.... looks nice down there.
Old 08-29-2007, 03:23 PM   #26
cdydjded
No harness is needed. Well if you do not want to cut then yes. But most of the connection are simple to make. The main harness that goes from the ECU to the engine on the left hand side has all the wires that need to be tapped into.
Old 08-29-2007, 07:26 PM   #27
thestereogod
militaryperformance.com
thestereogod's Avatar
Drives: 2003 SRT-4 2003 EVO VIII
Send a message via AIM to thestereogod
3. I don't like internal wastegates.
A system that only makes this much power doesnt need an external.....
2003 SRT-4 modded, alot. 2003 EVO VIII in pieces....
thestereogod is offline   Reply With Quote
Old 08-29-2007, 09:02 PM   #28
I don't know how much power a turbo will make yet. I also don't know what I might want to change after installing and tuning.
I just said I didn't like internal wastegates, not that they are bad or don't work. If I have a choice, I choose external -- if I don't have a choice, I look at the whole package (with power needs in mind) and make a decision.
Old 08-30-2007, 12:15 AM   #29
sciontc
Drives: scion
sciontc,
The main issue with the Yaris at this point is management. It does not have the same ECU as the Scion, so piggybacks like eManage don't work. Our ECU is "smart" and compensates for changes the piggyback tries to impose on it.
No one has an acceptable solution yet, including Todd, so we're waiting for someone to crack the ECU and/or come up with something less expensive than a standalone. After that, you'll see a LOT of turboed Yaris.
Like I said -- Todd seems to be a professional guy and his hardware looks great, but that is not a complete kit and it hasn't been installed in a Yaris yet.
(Todd did a motor swap on his Yaris instead, by the way.)
oh.
=/ my tuner is having problems with the tc's ecu too...it keeps compensating for hte changes that my aem f/ic makes
which by is an awsome management system. when it does work.
-shrug
sorry i don't know very muhc about yaris, i just wanted to let you guys know that he's a good and respectable guy =) wooo.
=X i like the liftback btw.
sciontc is offline   Reply With Quote
Old 08-30-2007, 07:06 PM   #30
Todd sent over a dyno of an xB running 9 pounds:
This is on a DynoPak chassis dyno (same thing Twins Turbo uses), which gives conservative and accurate numbers. Not bad!
