![]() Drives: RS 4 Door Hatch Join Date: Aug 2007
Rusty Muffler
I have a 2006 Yaris RS hatchback that went into service Nov 11, 2005. After a couple of winters on Ontarios salt covered roads the rear hanger for the exhaust has started to rust and has spread onto the rear surface of the muffler itself. What I was thinking of doing was to spray the rear of the muffler (or possibly the whole underside of it as well) with flat black manifold paint. I thought this also might be a visual improvement since I think the focus should be the tail pipe and not the silver (aluminum) rear of the muffler anyways.
Anyone ever try this? Would the paint adhere properly? Would I negate any kind of factory muffler warranty by doing this? For that matter should this be covered under warranty or would it only cover a large hole eating through the muffler. Thanks
06 RS 4 Door Hatch - Black Last edited by dadi_oh; 09-11-2007 at 01:27 PM. Reason: typos |
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
So you're just going to spray what's hidden? Sounds good. Even if it wares off, which it prolly will, just re-spray it.
Tantum religio potuit suadere malorum. |
46 and 2, just ahead...
Drives: 07 Yaris sedan Join Date: Jun 2007
Now that the rust has begun, I think it may have trouble adhering properly. I suppose if you scuff all the rust off (wire brush in a drill) you could make it work ok. Also, stove paint tends to come off, like the dust primer leaves, so try not to get it everywhere
Zero to Sixty in just fifteen minutes... |
^ Even paint cleaner would work if you want to apply the time.
#5 | |
06 RS 4 Door Hatch - Black |
There was some talk of it when Chris sprayed the inside of the wheel wells. You could search for that to see if any good info was brought up. Can't remember the title though, sorry.
ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
I have the same rust problem on both of my 2007 3 door liftback. Rust converter sounds like a good idea. Then spray paint. Muffers get hot and will burn off most paints.
| stock muffler interesting concept unbeknown to owners... | marcus | Performance Modifications | 7 | 08-16-2007 06:12 PM |
| What is the Most Quiet aftermarket performance muffler | thomasward00 | Performance Modifications | 18 | 08-03-2007 04:57 PM |
| F5 fujita air intake + megan muffler | westyaris2 | Performance Modifications | 4 | 07-17-2007 07:27 PM |
| Muffler Tip ~ Good Idea? | jaspie | Cosmetic Modifications (Exterior/Interior) | 14 | 01-17-2007 07:34 PM |
| CAI and Sports Muffler | littlecarlove | Performance Modifications | 18 | 11-04-2006 11:18 PM |
