Old 10-19-2008, 11:44 PM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Tokico HP (blues) Shock/Strut driving impressions.
For reference my suspension setup is as follows:
16X7 Konig Heliums
205/50/16 tires
Springtech 1.7 in lowering springs
TRD rear sway bar
Tokico HP dampers
So I got these about a month ago, and have been very happy with them. They are over $100 cheaper than the TRD upgraded shock/struts. The Tokico HP line is commonly refered to as "blues" because they are bright blue in color. Blues are valved stiffer than stock and are designed with lowered applications in mind. These are more performance oriented than the KYB GR-2 line, and ride nearly identical to the TRD KYB shocks and struts.
My car was lowered with the stock struts before I installed the Blues. The car rides a bit firmer, but does not compress, bottom out or wallow over high speed dips. It is much more surefooted on freeway ramps, and more stable over bumps. I have been very happy with them, and the ride quality did not degrade much, but the change is noticeable. I have rode in a car with TRD springs, TRD dampers and a TRD swaybar, and the ride of that car felt pretty close to my setup. Getting the Tokicos is a good way to save a few bucks if you want a performance setup without the expense of coilovers.
Old 10-19-2008, 11:54 PM   #2
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
Still waiting for Cali to carry these but, I'm sure hes busy getting his sponsored threads up again and Reposting the Hood Contest. Our cars look almost the same.
bdc87 is offline   Reply With Quote
Old 10-20-2008, 06:52 PM   #3
pinoypizzaboy
Drives: 08 toyota yaris LB
Smile
still waiting for these in the mail. did you use oem bumpstops for this?
pinoypizzaboy is offline   Reply With Quote
Old 10-20-2008, 10:56 PM   #4
largeorangefont
Break'em off some.
I cut the OEM bumpstops when I lowered the car. That is all you need to do if you car is lowered. If it is stock height, you don't need to do anything.
Old 10-20-2008, 11:20 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
Hmm i never cut my bump stops and never noticed a problem? But i have trd springs they are not that huge of a drop. What difference would i feel if i went back and cut them.
Old 10-20-2008, 11:54 PM   #6
largeorangefont
Break'em off some.
You should have cut them a bit even with the TRD springs. You will bottom out a bit less if you cut them, but you wont feel any difference under normal driving.
Old 10-21-2008, 12:22 AM   #7
YarisSedan
Wouldnt the bump stop keep you from bottoming out completely. Thus the stop reducing the amount of travel. Like going over a speed bump too quickly. I have lower tie bars that i keep hitting constantly. Im afraid if i cut the stops i may damage something underneight
Old 10-21-2008, 11:46 AM   #8
largeorangefont
Break'em off some.
Yes, that is the point of the bumpstop, to limit strut up travel. If a strut is compressed too much it bottoms out internally and that damages the strut.
You want to cut the bumpstop to maintain a similar amount of suspension travel as stock. If you had 4 inches, and lower the car an inch, you now have 3 inches of travel. You may hit the bumpstops more often over high speed dips or bumps. You can gain that inch of travel back by cutting the bump stops.
If you are not constantly bottoming out the bump stops, or satisfied with how the car is over those types of bumps, then leave the car the way it is.
Old 10-21-2008, 12:06 PM   #9
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I think if I were ever to redo my suspension, I'd go with the Tokicos and some Tein springs. I've had Tokico HPs on my Civic with H&R Sport springs, and it was a great daily driver setup.
Old 10-21-2008, 04:45 PM   #10
03Z33
03Z33's Avatar
Drives: TCR10
Do you know if the these have shortened shafts or stock length/travel?
Old 10-21-2008, 06:34 PM   #11
largeorangefont
Break'em off some.
These are stock length.
Old 10-21-2008, 07:27 PM   #12
03Z33
03Z33's Avatar
Drives: TCR10
OK, thanks.
Old 10-21-2008, 11:56 PM   #13
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
anyone know who has the best deal on these?
Old 10-22-2008, 01:42 AM   #14
DMart
same amount of posts lol
DMart's Avatar
Drives: 07 Meteorite Metallic LB
x2, i really need these, i think my stockers are about done...lol
DMart is offline   Reply With Quote
Old 10-22-2008, 10:31 AM   #15
largeorangefont
Break'em off some.
I paid $312 shipped from Neverenoughauto.com. They were a vendor here before the data loss. I believe WSCP has them for a similar price.
http://www.neverenoughauto.com/index...roduct_id=6363
Old 10-22-2008, 11:25 AM   #16
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Oh wow, thats a pretty reasonable price. I'll definitely keeps these in mind. Thanks for the review+info. You got a lot of fun stuff lately man, I'm so jealous.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 10-22-2008, 12:19 PM   #17
largeorangefont
Break'em off some.
Yes, these are a much better deal than the TRD parts.
If you end up getting them and need them installed, PM me.
Old 10-22-2008, 02:14 PM   #18
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Is your car scraping less in the front now that you have these shocks? Are you able to leave a drive-way without scraping?
marlondog is offline   Reply With Quote
Tokico Information nemesisz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-25-2007 08:21 AM
driving impressions Mead General Yaris / Vitz Discussion 14 05-06-2007 06:37 PM
