Old 10-21-2008, 10:22 PM   #1
09TRD
Drives: 09 Yaris hatch, 09 Z51 'Vette
Yaris Cabin Air Filter??
Does it come with one?
Does it have provisions to install one?
Where is it located?
Thanks
09TRD is offline   Reply With Quote
Old 10-21-2008, 10:28 PM   #2
09TRD
the canadian models have them , not sure about the us. but it is located behind the passenger glove box, you take out the glove box and you will see a long white piece of plastic thats the cabin filter compartment
Bosch lists one for the Yaris; they're PN is P3502.
Is anyone on the forum running a cabin air filter in their American Yaris?
Old 10-21-2008, 10:29 PM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
yes, any toyota dealer has a listing now for one.......
Old 10-21-2008, 10:30 PM   #4
09TRD
Thanks
Do you have a Toyota PN?
Old 10-21-2008, 10:31 PM   #5
pixiedixie862
Drives: Scion xA
i think this was on here before and they are so many diy for this... instead of buying one just make one :)
ah here it is, http://www.scionlife.com/forums/view...y+cabin+filter
pixiedixie862 is offline   Reply With Quote
Old 10-21-2008, 10:34 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
Originally Posted by 09TRD View Post
Thanks
tomorrow morning.....
Old 10-21-2008, 10:36 PM   #7
09TRD
I saw one DYI; roughly one-third of the flow area was cut off by the cardboard of the cut-up filter, which was based on a 3M home furnace filter. Those filter elements are too restrictive for the Yaris's small fan.
I'm not interested in anything like that.
Here's the Toyota PN:
http://www.brandsport.com/toy-87139-...ota-yaris.html
This filter element is only $8.70:
http://cpwstore.carpartswholesale.co...filter+t420103
The Bosch cabin air filter for the Yaris (PN P3502) is $19.99 in my zip code area, per their website. I'll order two of those tomorrow.
Old 10-21-2008, 10:37 PM   #8
09TRD
Looks like it's 87139-52020
Old 10-21-2008, 10:38 PM   #9
ROCKLAND TOYOTA
TRIM HUNTER
any one of those will work.....
Old 10-21-2008, 10:40 PM   #10
pixiedixie862
Drives: Scion xA
check this one out... its better than the one that you looked at. I dunno i just think it might save you some bucks
Old 10-21-2008, 10:46 PM   #11
09TRD
That's interesting.
Are you certain that the Yaris has a pull-out frame like the Scion xB, though? (I don't think it does. See pics here: http://www.yarisworld.com/forums/sho...bin+air+filter )
Here's the drop-in Bosch cabin filter. The PN for the Yaris filter is P3502; they're $19.99 at Autozone. I'm going to order two of those tomorrow.
http://www.boschautoparts.com/Produc...AirFilters.htm
Old 10-21-2008, 11:12 PM   #12
kimona
kimona's Avatar
Drives: 2014 White VITZ
The Yaris does not have a pull-out filter frame like the Scion; there just isn't enough clearance to install and remove the frame. This is precisely the reason why Toyota did not install a filter in the unit. Nevertheless, a filter can fit without using a frame. To install the filter, it's a bit of a sqeeze but quite doable. Don't buy the filter frm the dealer unless you have a small fortune to plunk down. Go to your local auto parts and pick one up. I got a Purolator for less than $10. Part # is: C38188.
Old 10-21-2008, 11:55 PM   #13
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
it is amazing how much particulate matter the 3m filtrete based filter I made picks up. I used some adhesive foam strips around my filter to help create a more air-tight fit. It fits in snugly, and I can't tell any difference in air flow rates. I'm sure there is some change, but its impossible to filter without some change.
Old 10-22-2008, 12:00 AM   #14
b_hickman11
Drives: 08 Sedan
I have one in each of my Yarises.... $8.99 from O'Rielly's
Old 10-22-2008, 12:30 AM   #15
YarisSedan
Drives: 08 Yaris Sedan
Get a wix one. Its got taht special technology they are using on new countertops that has these spiky things in it that is supose to prevent any bacteria from ever growing. Somehow pierces them or soemthing lol.
Old 10-22-2008, 12:49 AM   #16
IsLNdbOi
IsLNdbOi's Avatar
Pep Boys carries Purolator filters that fit the Yaris. It fits the LB, not sure about the sedan or 5-door LB.
Old 10-22-2008, 01:25 PM   #17
b_hickman11
Drives: 08 Sedan
Originally Posted by jimtevin View Post
US does not come with them..get one form dealer for cheap, take out glovebox, and slides right in. Very easy.
they are not cheap at the dealer.....$25 average
Old 10-22-2008, 01:44 PM   #18
1stToyota
1stToyota's Avatar
I got mine from the dealer, after I sent back the Wix/Napa Gold. The OEM didn't look as restrictive, which should make the blower motor and resistor much happier.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
Air conditioning filter Geelmeel DIY / Maintenance / Service 41 10-31-2010 10:02 PM
