Reinforce Jack points?
I change my tires often and with a regular 2 ton garage jack and jack stands but the metal rail on the underbody is starting to bend. Is anyone else having this problem?
I have considered welding in some reinforcement along the rail or maybe getting rubber pads for the jack, but if its just me then maybe I'll take it to the dealer and complain. I know cheap car, cheap materials but just throwing it out there...
I use 3/4 pine plywood between any of jack stands and jack. It absorbs the pressure and does not damage the frame.
Considering welding in some reinforcements... I'll keep this thread updated, but school is busy this time of year so possibly over thanksgiving or winter break I can get something done - thanks!
#4 | |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Try this...Take a hockey puck, and on a table saw, and cut a grove down the middle.. works great!..
I use it for the jack and also with jack stands.. For the jack stand, you will need the flat top style, not axle stands.. Quote:
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Great Idea
Making a decision without following it with an action is still a fantasy. |
Are these jack point new to the 09? This is from my owners manual:
i just use a piece of leftover 2x4 i have kicking around my garage...disperses the load evenly enough...
#9 | |
Your link does not seem to be working.. Can you try again?
thanks Quote:
#10 | |
The reason I posted the manual page above is that I noticed that it didn't seem to be included in prior year manuals (or a least the 07 one that I had). All vehicles have better lift points for maintenance than the body points intended for use with the oem jack. |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
Sorry but that's a rediculous idea....I've had my 2007 for nearly two years, and I use s 2-ton jack too...just make sure the split metal on the jack are worked over the body seam designated for jacking up the car. My seams are not bent, and are in perfect condition, and I rotate my tires every 5,000 miles...presently I have 44,000 miles, and still no issues. Welding on or near body parts can change the temperance of the metal, and remove the integrity that the factory wants for those parts....in addition, doing this could void your warranty....just be more careful about how you place the jack under the car and you too will have no worries....
#12 | |
![]() http://www.northerntool.com/webapp/w...5429_200345429 |
Yes, the 2006+ Yaris LB has central jack points, front and rear. If you're lowered, good luck getting to them. If not, you're golden.
#14 |
![]() ![]() ![]() Drives: 08 toyota yaris LB Join Date: Oct 2008
how do you guys jack it when its lowered?
#15 |
#16 | |
... Almost to the point where I can just about visualize the under body more than I can the actual body, I'll try and post some pictures of what I'm talking about -As for the link, http://rmgsupply.com/products/RUBBER...1-1233-52.html ![]() maybe not that exact item but something similar, the military base I used to go to had these rubber pads on the ends of their jacks sort of like these
#17 |
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
The hockey puck idea is great, but there aren't many of those just laying around here in southern California. I use a 4" long piece of 2x4 with the same slot cut in it. It doesn't look nearly as trick, but the material is readily available.
![]() Those central lift points are on my '08, too. |
#18 |
Here's another suggestion guys: http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
| Is MP3 AUX Jack Grounded properly? | iseraph7 | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 07-16-2009 05:51 PM |
| Factory AUX Jack | ojo | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 06-06-2007 09:41 PM |
| aux jack | SurfBabe900 | New YARIS Purchase Forum | 12 | 06-04-2007 02:06 PM |
| New Floor Jack | blacksan | Off-topic / Other Cars / Everything else Discussions | 5 | 05-16-2007 02:32 PM |
