Old 10-28-2008, 08:03 AM   #19
IsLNdbOi
IsLNdbOi's Avatar
The pin for the speaker's +wire and -wire in the harness? How would that work? I wouldn't be able to plug the harness back in I think.
Old 10-28-2008, 08:15 AM   #20
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
you pull them out solder the wire to it and stick it back in it will go back in theres enough room
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-28-2008, 06:06 PM   #21
IsLNdbOi
IsLNdbOi's Avatar
Anyone else have ideas on how to connect the LOC w/o tapping into, cutting or splicing the stock wiring?
Old 10-28-2008, 06:38 PM   #22
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Well isnt that the whole point of a LOC is so you can tap the existing wire? You can find exposed wires and 'twist' them and pray for the best, though the connections will be weak and so your sub wont sound so good. If it works ok, those connections will most likely losen over time. Its easier if you just work with the harness and tap the wires from there. If you dont wanna cut, splice, solder, tap the wires your only otherway would be to buy a HU with RCA outputs.
BTW battleversiontc, were you the one helping me with LOC pre-hax?
I'm not an expert, but I did what battleversiontc mention in THIS thread and it worked out for me.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 10-28-2008, 06:54 PM   #23
IsLNdbOi
IsLNdbOi's Avatar
I think I've found a solution.
Get this:
Metra harness adapter (plugs into car-side of HU harness)
http://retailer.installationexcellen...hicleid=219980
Metra harness adapter (plugs into stock HU)
I think you can see where I'm going with this. I can twist the LOC's wires with a speaker's wire on both harness adapters, match the rest of the wires then plug each harness adapter into their respective places (one end into the HU's car-side harness and the other end into the HU).
Old 10-28-2008, 11:01 PM   #24
battleversiontc
i think so
yeah you can do that to if your trying to keep your wires from being tapped into
Amp with Stock Head? Boy Blue In Car Entertainment + Electronics (audio / video / alarm) 11 06-11-2011 12:53 PM
Amp and Sub on Stock 6CD changer Q DjT In Car Entertainment + Electronics (audio / video / alarm) 2 07-15-2007 08:12 PM
small 4ch amp. 4x100rms ben dover In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2007 05:17 PM
Custom Sub Enclosure (inc sub, power cap, amp) wado Items for Sale by private party 3 09-18-2006 12:53 PM
