Old 09-13-2007, 08:48 PM   #55
WolfWings
WolfWings's Avatar
Originally Posted by brickhardmeat View Post
205/50/15 is my #1 choice on this car. It will only slightly thow the speedo and the odo at 10000 will likely read 10300 not enough to make any difference for me.
Hell, the factory 15" OEM versus 14" OEM tires have more of a difference than that. 10000 on the 15" factory tires would read as 10400ish on the 14" factory tires.
Old 09-28-2007, 11:31 AM   #56
c-one yaris
c-one
Send a message via AIM to c-one yaris
lowered... need help on some rims and tires
i lowered my yaris with the tanabe DF210 springs... i want to know if these will fit my car WITHOUT ANY KIND OF RUBBING WHAT SO EVER:
RIM:15"x7" DRAG DR-30
TIRES: 225/50/15 Falken ZEIX ZE-512
AND if you have any suggestions i would also appreciate that.
THANKS!
c-one yaris is offline   Reply With Quote
Old 09-28-2007, 11:53 AM   #57
Black Yaris
der Zeck
Black Yaris's Avatar
no they will not fit with out ANY rubbing, that is why I got rid of my my 225/50R15's
Old 09-28-2007, 11:58 AM   #58
c-one yaris
c-one
ok. now what's the widest i can go on 15", 16", and 17"?? better yet, is there an official tire guide for lowered yaris'?? that be a lot easier. Thanks Black Yaris!
Old 09-28-2007, 12:09 PM   #59
Black Yaris
der Zeck
widest you realy want to go on the front is a 205 when you are lowered, you can go 215 in the rear... you want to run staggard or not?
here are some recs to run all the way around
15-205/50, 205/55
16-205/50
17-205/40, 205/45
Old 09-28-2007, 12:11 PM   #60
kimona
kimona's Avatar
Drives: 2014 White VITZ
That answer depends on wheel width and offset.
If you post those specs, we can probably help you with tire sizing.
Old 09-28-2007, 12:13 PM   #61
Black Yaris
der Zeck
true... I was just giving general sizing options
Old 10-21-2008, 09:36 AM   #62
Energiser
Oh, Shiny...
Energiser's Avatar
Drives: 2005 Toyota Yaris YR
Hey guys,
I'm looking at getting some new wheels for my Yaris. It's been a fairly lengthy process with me finding something I like, then finding it isn't appropriate for one reason or another (usually associated to my expensive taste, and the fact I'm trying to get nice 16" wheels in Australia...)
The wheels I'm looking into at the moment are Enkei SC03's, 16" x 7", pcd of 4x100, and am planning to put 205/50/R16 rubber on them. The problem comes when I'm trying to figure out the offset.
From what I can find online, these wheels come in a +35 variety, and a +43 variety. I've noticed a few people on the forums with slightly larger offset on the front as opposed to the back (say +42 on front, +36 on back) and was wondering if it's worth going to that sort of trouble, or if I'm better off going +43 all around?
I haven't gone looking for quotes on these yet, wanted to finalise what I want before I start... so for all I know, these could be more expensive than I'm willing to pay, too.
Regards,
Energiser
Edit: Where on the Yaris is the tyre placard generally located? I can find a sticker inside the glove box which mentions my stock 14 x 5 steel wheels, but I thought they were supposed to list the range of wheels suitable for the car. Or at least the range available from the dealership as options (which are 15 x 6 here in Australia).
Energiser is offline   Reply With Quote
Old 10-21-2008, 02:19 PM   #63
kimona
kimona's Avatar
ET43FR//ET35RR would make a great staggered offset with 205/50 rubber. I run a set of 45/38's on mine with 205's and the fitment is excellent. I'm not a fan of tyre rotation, so that's not an issue for me... but, it may be a consideration for you.
Old 11-03-2008, 07:24 PM   #64
arunto
arunto's Avatar
Drives: 2008 Yaris LB
Will 15x6.5" 38mm offset with 195/55/15's with Tanabe DF's rub?
arunto is offline   Reply With Quote
Old 11-10-2008, 05:59 PM   #65
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Help!
i want to get these rims.
http://www.axiswheels.com/wheels.php?id=racer-x
15x7 in the front and 15x8 in the rear. I know the front will be fine, my only worry is the -.27 offset on the rear wheels. can it be done? Also i'm dropped on Tanabe DF210's
Old 11-10-2008, 06:30 PM   #66
mchllp925
Darrin
mchllp925's Avatar
Drives: 2008 yaris le h/b
Hello everyone.
So for clarification...I use racing discs over my 185/60R15's allseasons, can I put 205/50R15's on my Yaris without any issues such as rubbing? I do not intend to lower my car.
I just want wider tires. And if so, do you think it would throw off the speedometer?
mchllp925 is offline   Reply With Quote
Old 11-10-2008, 07:36 PM   #67
kimona
kimona's Avatar
Originally Posted by mchllp925 View Post
Hello everyone.
If you're not lowering, then install 205/55/15's with no worries. 205/50/15's are too short with stock suspension. Your speedo will be fine.
Old 11-10-2008, 08:19 PM   #68
Black Yaris
der Zeck
oh shit, i almost forgot about this thread.... I will do some updating to the first post
Kimona, feel free to make any edits you see fit
Old 11-10-2008, 09:05 PM   #69
mchllp925
Darrin
mchllp925's Avatar
Thanks for the quick reply Kimona.
Appreciate it!
Darrin
Old 11-14-2008, 06:48 PM   #70
darthbauer
Not really here...
darthbauer's Avatar
So will these fit and rub?
17x7.5 offset is 45 wheel with 215/40 rubber?
Liberate Tutemet Ex Infernis.
Old 11-14-2008, 07:47 PM   #71
kimona
kimona's Avatar
Are you lowered, and if so, how much?
Old 11-14-2008, 07:48 PM   #72
kimona
kimona's Avatar
Okay. I'll take a peek later.
EDIT: I've made a few changes to the wheel/tyre guide. I'll get back to it another time and update tyre size recommendations.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 01:51 PM
