Old 03-03-2006, 12:21 PM   #37
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
So you've done tests with it? If so, where is your data? If not, you can't possibly know if it does something or not.
Old 03-03-2006, 07:32 PM   #38
swng
swng's Avatar
Drives: 06 3-dr auto RS
Originally Posted by AutoTech1
It won't void the warranty. Sure, you can use a higher octane, but you'll void common sense, if you void anything...
I was talking about whether adding acetone to the gasoline(not about using higher octane gas) could void the car's warranty. Yariman seems to agree that this is a reasonable concern(thanks Yariman). I think it is common sense that putting uncommon additives into the gasoline may void the warranty.
swng is offline   Reply With Quote
Old 03-03-2006, 10:03 PM   #39
AutoTech1
Drives: None yet
Sorry. I thought you were asking about octane still.
As with acetone, it makes perfect sense, but I have never tested it, so I can't say that it does/doesn't work... But how it was explained, it sounded like it'd work.
AutoTech1 is offline   Reply With Quote
Old 03-03-2006, 11:25 PM   #40
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
from experince with previous cars i've only used 91 octane on long distance drives and there you do see a difference, since the long drive cleans out the car the high octane help also. with my paseo normal gas i got abot 400km and with 91 octane 430km. for my corolla 440km normal 465 km 91 octane. I'll see when i make that trip to toronto in the spring.
Adriaan is offline   Reply With Quote
Old 03-04-2006, 01:29 AM   #41
swng
swng's Avatar
How about this? New cars benefit little from higher than user's manual specified octane no. but old cars benefit more. In my experience, new cars do not knock/misfire often(knocking will automatically result in low efficiency). Old and badly maintained cars knock more often and so they stand to benefit from higher octane no. fuel.
Old 03-04-2006, 09:53 AM   #42
why?
why?'s Avatar
Drives: Yaris LB
lol, ok.
Old 03-04-2006, 01:59 PM   #43
AutoTech1
Drives: None yet
That doesn't mean anything. Many things could have altered your gas mileage... Like how you drove the car the first time compared to how you drove it the second time. You might have been going slower, and burned less gas. The other time you might have been going faster and burned more gas. And that is a likely thing to do, if your repeating the same route, since you know where to go. Hey... If you think you can prove me wrong though, keep trying. But you won't go no where.
Old 03-04-2006, 02:03 PM   #44
AutoTech1
Drives: None yet
I would never use a higher octane on a older car... Again, you're just wasting your money... Either get a tune-up (which should target or solve the problem) or get a newer model year car. Engine's wear... Timing changes, rings wear, aluminum parts break down so on and so forth. That knocking is most likely a result of a car that's gone bad after years.
Old 03-04-2006, 04:42 PM   #45
swng
swng's Avatar
For now, I will not rule out using higer octane fuel in old cars as a short term measure. Maintenance is the ultimate solution if a new purchase is out of the question for one reason or another. Let's hear more comments from our knowledgeable fellow members. I am sure there are very well qualified people among us.
Old 03-04-2006, 11:53 PM   #46
swng
swng's Avatar
Originally Posted by GabL
Use what is recommanded in your user manual...
http://autorepair.about.com/od/engin...hoctanegas.htm
I refer to my previous post and the link recommended by Gabl above(Thanks Gabl!).
I am not here to convince anyone to use higher octane fuel on old and not so well maintained cars(NB: more old than new cars are not too well maintained because of lack of warranty and regular attention or willingness of the owners to invest further money in them; lots of exceptions exist though). I do not think I ever can.
Yet, I wish to point out that I have based my comments on the paragraph under "Should You Ever Switch to A Higher Octane Gasoline?" of the linked article. Obviously, the writer thinks it is o.k. to try using higher octane fuel first when knocking is detected on a car (on which the user's manual recommended grade of fuel is already in use). If the problem persists, then he reommends to have the car repaired or tuned up, which is utterly logical.
Old 03-05-2006, 04:47 PM   #47
AutoTech1
Drives: None yet
Originally Posted by ToTo
Acetone only destroys rubber, hoses and perhpas plastics, can it harm the engine or other parts itself?
I was thinking it could do that too, but I wasn't sure. It sounds like some alcohol. Is that what it is?
As for the engine, I don't think so...
Old 03-05-2006, 04:49 PM   #48
AutoTech1
Drives: None yet
Don't get me wrong. I agree that using higher octane on a older car would work. I understand what you're getting at. But I just wouldn't do it. I'd rather get a newer car.
Old 03-05-2006, 04:58 PM   #49
swng
swng's Avatar
Point understood friend!
Old 03-06-2006, 10:04 AM   #50
why?
why?'s Avatar
Drives: Yaris LB
No. Acetone is what they use for paint thinner, nail polish remover, etc.
What is supposedly does in the engine is make the water is the gasoline come apart easier, making the engine able to burn the fuel more completely.
Alcohol, which is water based, would do the exact opposite.
Old 03-06-2006, 07:58 PM   #51
AutoTech1
Drives: None yet
Thanks.
I don't think I'd use it though... Rubber seals and stuff... Ahhhh... Doens't sound pretty.
Old 03-07-2006, 09:05 AM   #52
why?
why?'s Avatar
Drives: Yaris LB
If it actually does anything to them. The person who wrote the website stated that he has soaked hoses and other parts in up to a 20% acetone/ 80% gasoline solution for months, and has seen no adverse affect except in the highest concentration he used to test that theory. Considering 3 ounces to 10 gallons is a .002 % concentration.
Old 03-07-2006, 03:54 PM   #53
AutoTech1
Drives: None yet
Yeah true... You do make a good point.
Old 05-29-2006, 12:15 PM   #54
DollaZo
DollaZo's Avatar
Drives: Toyota Yaris YRS
sup all
just letting you all know that when I first got my Yaris 1.5L i thought that if I had put expensive fuel in the car that it would benefit my car. 91 octane being cheaper than 98 which is what I put for about 3 months. After a while I started to notice that the car was being harder to drive in terms of playing with the accelerator and the clutch. After speaking to a family friend he recomended me to start using 91 octane. Instantly I noticed that the car was easier to drive, it felt as if the car was happier to drink 91 than 98. So in my opinion I would not recomend using 98 octane as the car was made to run with 91.
DollaZo is offline   Reply With Quote
