Old 11-17-2008, 01:53 PM   #1
bnther36
Drives: 07 Yaris Sedan
Windows won't un-fog
I'm just curious to see if anyone else is having window fogging issues. I've never had so much trouble with this on my other cars, but the little Yaris just does NOT want to cooperate.
bnther36 is offline   Reply With Quote
Old 11-17-2008, 01:55 PM   #2
ChinoCharles
Drives: LB
Turn your AC compressor on along with your defroster. The problem is with removing the humidity from the air in your vehicle, which your AC system will do.
Old 11-17-2008, 02:01 PM   #3
Chupacabra
Drives: 2009 Yaris liftback
and have it on recirculate mode, correct?
Chupacabra is offline   Reply With Quote
Old 11-17-2008, 02:04 PM   #4
SailDesign
Drives: .
OK - you two need a time-out. Sorry, Chino, but....
1. The AC automatically turns on "when needed" with the defrost aimed at the windscreen. Nothing you can do to stop it - I've tried.
2. Recirculate will not get rid of fog - stick it on "fresh air".
3. Flame on! (probably)
Old 11-17-2008, 02:06 PM   #5
Revsson
I agree with #1 and #2 above.
Old 11-17-2008, 02:07 PM   #6
ChinoCharles
Drives: LB
... I'm driving down the road. Its cold out. My windows are fogged up. I crank the defroster on high. Nothing. I hit the A/C button and within about 5 seconds my windshield is clear.
That happens, oh, every day during the winter.
Old 11-17-2008, 02:25 PM   #7
SailDesign
Drives: .
Dang! Want to trade? I cannot turn off the AC when defrosting. Says in the handbook that's what it does, IIRC.... Strange.
Old 11-17-2008, 02:38 PM   #8
voodoo22
Drives: Yaris Sedan (auto)
When my windows fog, and I turn it to defrost, the A/C goes on automatically as well. That's how most newer cars are from my experience.
voodoo22 is offline   Reply With Quote
Old 11-17-2008, 02:42 PM   #9
Fog-X works pretty good and also using shving cream on the window and wipe it off...don't knock it until you try it
Old 11-17-2008, 02:42 PM   #10
steved
Yaris Rules!!
Drives: 2007 Red Yaris Liftback a/t
Get your system checked. When my windows are fog up I put it on defrost and it clears up right away.
The secret of life is honesty and fair dealing. If you can fake that, you've got it made.
Groucho Marx (1890-1977)
steved is offline   Reply With Quote
Old 11-17-2008, 03:12 PM   #11
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Turn on the A/C, fan, and defroster. Turn the knob to "defrost" setting. If that doesn't work, then crack the windows a little to let some of the humidity out. Never fails.
Old 11-17-2008, 03:40 PM   #12
SailDesign
Drives: .
Well, I stand corrected (although I'm sitting down)
Following is from the '07 Owners Manual, showing that you DO need to push the button. Dunno where I (mis)understood that it was turned on automatically.....
Old 11-17-2008, 04:17 PM   #13
darthbauer
Not really here...
darthbauer's Avatar
I just put it to fresh air and click it on to 4 and all the way to heat and the fog goes away in less than a minute.
Liberate Tutemet Ex Infernis.
Old 11-17-2008, 04:46 PM   #14
We used to have a thread or two which debated whether or not the A/C compressor came on automatically in the Defrost setting. Topic I think came up during fuel economy discussions. Still don't know if any definitive answer surfaced.
My personal experience is the defrost setting will clear the window in seconds with no need to push the A/C button.
Old 11-17-2008, 04:54 PM   #15
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Check to see that the body plugs are in place and not allowing more moisture in..... feel your carpets to see if they are wet too.
Old 11-17-2008, 05:41 PM   #16
bnther36
Here's some pics of my windows after 45 minutes of driving with the defroster set to recirculate, medium heat, and #4. I tried switching to regular heat, instead of defroster and within 60 seconds the windshield started fogging up. And it's THICK when it does fog up.
I've never had a car do this before.
Old 11-17-2008, 05:55 PM   #17
BailOut
Steals terrorist's lunch
BailOut's Avatar
I commute over a mountain that sees over 300 inches of precipitation per year and I have never used the a/c or defrost setting. When the windows fog all I do is crack the window and in a few seconds the windshield is clear.
- Brian
Share the Road
Old 11-17-2008, 06:44 PM   #18
SailDesign
Drives: .
It's the "recirculate" that is killing you there. Been there, done that, noticed the problem - all fixed!
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 02:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-03-2006 12:38 AM
rear corner windows fogging wushumasterku General Yaris / Vitz Discussion 14 01-23-2006 04:09 PM
