Old 08-12-2006, 06:59 PM   #1
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
df210
just finished installing the df210 spring.. maybe it because of the bad qualite of the road here.. but when i hit BIG hole.. not normal hole it rub .. but i give a very nice loook :p maybe because of the tire.. 205/40 17
OxyG3nE is offline   Reply With Quote
Old 08-12-2006, 07:17 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Well you said you hit a BIG hole... and you are now that much lower... what did you expect??
Old 08-12-2006, 07:20 PM   #3
OxyG3nE
damn that mean i have to drive with the eye on the road now lol
Old 08-12-2006, 07:25 PM   #4
OxyG3nE
anyway very goood you how-to chris help me a lot! but took me 4 hours to change it hahah
Old 08-12-2006, 08:13 PM   #5
Chris07LB
Chris07LB's Avatar
Glad it was of some help.
Old 08-12-2006, 08:44 PM   #6
Linkseal
Drives: DBA-NCP91
Send a message via MSN to Linkseal
Can't wait to see your new pics with lowered car...
Linkseal is offline   Reply With Quote
Old 08-12-2006, 08:58 PM   #7
OxyG3nE
i looked and the tire 205 are too large .. they rub on the outside .. maybe i can find a way to fix it or leave it like that lol will see in a week the result.. if it going bad i put the stock coil ;p
Old 08-12-2006, 09:13 PM   #8
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Whats the offset of your wheels, and do they just rub on the inside of the fender well?
Old 08-12-2006, 09:30 PM   #9
OxyG3nE
40 for the offset and they rub juste a little on the plastic on the inside maybe i can unclip it.. night was coming and couldnt work on that ;p
Old 08-12-2006, 11:27 PM   #10
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Do you guys think this drop will ever rub with the stock 185-60-15 on the car? Just wondering because it was very low!!
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 08-12-2006, 11:30 PM   #11
OxyG3nE
i dont think because first the stock wheel are a little smaller(diameter) than what ive put.. and mine are much larger..
Old 08-13-2006, 01:11 AM   #12
riceboy
Drives: icebox
becareful if you have rubbing issues... and make sure to get an alignment done... you don't want any premature or unusual wear on your tires...
riceboy is offline   Reply With Quote
Old 08-13-2006, 12:16 PM   #13
OxyG3nE
doing the allingnement monday.. and anyway if anything happen with the tire
ill buy new one lol
Old 08-13-2006, 05:30 PM   #14
slvryaris
slvryaris's Avatar
Here is the differences in the tires. You would be suprised at the small difference. I think its because the offset on the stock rims. Does anyone know what that offset is on the stocks?
185/60-15 4.4in sidewall 11.9in Radius 23.7in Diameter
205/40-17 3.2in sidewall 11.7in Radius 23.5in Diameter
185/61-15 74.6in Circumference 850 Revs/Mile
205/40-17 73.7in Circumference 860 Revs/Mile
Old 08-13-2006, 06:22 PM   #15
OxyG3nE
i had 14 inch rim stock with 175/65 tire on
Old 08-13-2006, 07:04 PM   #16
Chris07LB
Chris07LB's Avatar
No rubbing here... DF210's
Old 08-13-2006, 08:54 PM   #17
slvryaris
slvryaris's Avatar
Here is the tire calculator I use. Just put both the old tire size and the new tire size and they compare them.
http://www.eunos.com/tirecalc/
Old 08-13-2006, 08:59 PM   #18
slvryaris
slvryaris's Avatar
Hey Chris do you have any idea what the offset is with the stock wheels on the 185/60/15's. We were worried that +40mm wouldnt be enough and now it seems to be too much. I have 215/40's on with a +40mm offset and I took it to a friend of mine that does suspension work and he said I should be ok from rubbing.
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 01:28 AM
Any photo with DF210 sedan 4 doors mariosuper Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 07-26-2006 03:04 AM
IS DF210 is lower than Nf210 ?? mariosuper Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 07-08-2006 11:36 PM
