Old 11-21-2008, 05:25 PM   #1
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Snow tires = poor mpg
Less than impressed with my new MPG since I mounted the blizzaks on the Yaris. I dropped about 4 MPG
Old 11-21-2008, 06:10 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Ah, but those little suckers will rip through some snow and ice, won't they?
(I've never used them, but I know folks who have... they're pretty amazing tires for what they're designed for)
Old 11-21-2008, 06:31 PM   #3
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
They are a great tire and with the hundreds of sipes.... they are grippy little devils. I am impressed with the highway attitude.
For the last few years I used DUnlop Graspics which were basically the same desing but the car they were on (Chev Impala) never suffered a MPG drop like this.
This weekend I will increase the air pressure to see if it helps.
Old 11-21-2008, 09:21 PM   #4
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
I have a set of studless Toyos...haven't noticed a difference in mileage, but I'm sure they're not as grippy as the ones you have.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 11-21-2008, 10:03 PM   #5
JnC
Drives: 00 VW Golf TDI
Makes sense. You need low rolling resistance for mpg, yet you have grippy tires for snow.
You might consider Nokians. Can't completely overcome the physics of the above, but they do advertise low rolling resistance for their WRG2 tire. More of an all-weather tire, it does have some good winter design traits.
If you do want an all out winter tire, try the Nokian Hakkapeliitta's. Some of those claim lower rolling resistance.
JnC is offline   Reply With Quote
Old 11-21-2008, 10:55 PM   #6
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
I had Hakkapeliitta's on a car a while back and I was not impressed. They wore quick and did not do the job. Time will tell.
Old 11-22-2008, 12:00 AM   #7
I ran Blizzaks way back when on a Civic wagon. I also saw a significant MPG reduction during snow tire season. Besides the boat show like sipes, the Blizzaks are made of a very soft/sticky rubber that is awesome on ice and like velcro on dry pavement. The composition also makes them wear way quicker than any other tire I have ever run.
A buddy of mine runs Hankook Ice Bears on his VW Pasat and swears that they are as good as Blizzaks without the wear issue...
Old 11-22-2008, 03:20 AM   #8
gid
we use studded COOPER Weather Master ST-2s all the way around on the '08 sedan . They were on the '08 Liftback last season and did a fine job . We've been averaging 37 m.p.g. since installed . That's not so bad . This includes colder weather and 87 octane SUNOCO that's a 10% ethanal winter blend . The tires are kept at around 35 p.s.i.. They dip to little under 33 p.s.i. on the colder days . Try to check them once a week due to variations in pressure from temperature changes .
Old 11-22-2008, 04:21 AM   #9
06vitzRS
Drives: 06 Yaris HB
Since i put my winters on i've gotten the best mileage yet. Seems odd i know but I put 675km on my last tank. I usually get close to 600. Been running them with 34-38psi.
http://www.nokiantires.com/tyre?id=1...akkapeliitta+R
4th year apprentice mechanic.
06vitzRS is offline   Reply With Quote
Old 11-22-2008, 07:45 AM   #10
nemelek
DWEED
nemelek's Avatar
We are lucky to not really need snow tires in Denver. Once or twice a year we could use them, however the snow usually melts in a day or so. The road crews use so much magnesium cloride that black ice is never an issue. I worry about the long term effect the salt will do to the car. The ski industry is so big that the road crews work around the clock to keep the roads passable.
Old 11-22-2008, 09:24 AM   #11
GeneW
Drives: 2008 Yaris
I have Kelly Springfield M&S tires. I notice minimal changes in MPG. Aside inflation I wonder if they're the same size as your summer tires?
Gene
Old 11-22-2008, 11:00 AM   #12
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
are you sure you didnt drop mpg because of the cold weather....?
Old 11-22-2008, 11:36 AM   #13
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Gene
Same size
Maybe but it's a blistering 20 F right now!
Old 11-22-2008, 02:07 PM   #14
nemelek
DWEED
nemelek's Avatar
For the brown cloud, the refineries here use MTBE (Methyl Tertiary Butly Ether) in their winter gas blend. I have suspected for years that MTBE effected gas milage. http://www.fee.org/pdf/the-freeman/heberling0903.pdf
Old 11-22-2008, 06:21 PM   #15
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
MTBE was banned years ago in the gasoline in this area since it is related to cancer.
Old 11-22-2008, 09:07 PM   #16
GeneW
Drives: 2008 Yaris
Slightly warmer here in PA. The folks who bitch about the cold are reminded by me that insects do not like cold weather and die off before they grow too large or too numerous.
We could really use some zero degree F days, maybe a week of them, to waste the mosquitoes and gnats in their winter hidey holes.
Gene
Old 11-22-2008, 09:13 PM   #17
GeneW
Drives: 2008 Yaris
It's also a very "stable" chemical that leeches into water tables and never goes away. Ethanol is better since it's readily biodegradable, even by human beings.
Gene
Old 11-23-2008, 03:45 PM   #18
floydisrock
73 Centurion droptop 455
floydisrock's Avatar
Drives: 2009 S Sedan
I still think 32 mpg with winter fuel and snow tires is terrific.
"THIS SITE HAS BEEN HACKED BY www.bimmerfest.com. YOU FUCKERS!"
floydisrock is offline   Reply With Quote
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 07:40 PM
snow tires - which ones? platypus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-05-2008 02:06 PM
Snow tires Phaeton Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-30-2008 09:43 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 02:23 AM
FS: Stock tires on steelies spkrman Items for Sale by private party 9 04-12-2007 07:45 PM
