Old 11-14-2008, 07:55 PM   #73
darthbauer
Not really here...
darthbauer's Avatar
Right now I am not lowered. If I do lower I will go with the TRD sportivo set up with the shocks and springs.
Liberate Tutemet Ex Infernis.
Old 11-14-2008, 08:22 PM   #74
kimona
kimona's Avatar
Drives: 2014 White VITZ
17x7.5 ET45, 215/40 rubber. Should be okay with TRD drop.
Old 11-17-2008, 10:31 PM   #75
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
u wont rub with that. any takers for my question above?
Old 11-17-2008, 11:33 PM   #76
kimona
kimona's Avatar
Here you go...777:
"...the one of a kind 15x8 has a 5 inch lip! This is done with a negative 27 offset, and can only fit the most extreme widebody fitments."
Old 11-24-2008, 07:39 PM   #77
DJexor
Drives: AE86´85 | Yaris T-sport '01
Hello there, I see all sizes for a new Yaris. Does anyone know what the max offset would be on an 2001 TS model (oldest model)? Would prefere 17". Thinking of Work CR Kai 17x7 off +42
DJexor is offline   Reply With Quote
Old 11-24-2008, 08:30 PM   #78
kimona
kimona's Avatar
Don't know what the min/max wheel/tyre fitments are for the 2001 model, but I believe that 17x7, ET42 should work... no worries.
Old 11-24-2008, 08:36 PM   #79
Black Yaris
der Zeck
Black Yaris's Avatar
you can run low offsets similar to the scions if you want
Old 01-21-2009, 09:11 PM   #80
hafeez
Drives: 2007 Silver Toyota Yaris Sedan
i am going to lower my yaris sedan with the tanabe DF210 springs. i just want to know if these rims will fit without it rubbing or causing any problems. They are 17" x 7" Tenzo Passion 5 ET42 wrapped in 205/40/17 Kumho Ecsta tires. Thanks in advance.
hafeez is offline   Reply With Quote
Old 01-21-2009, 09:19 PM   #81
kimona
kimona's Avatar
Should be okay with that setup.
Old 01-21-2009, 09:38 PM   #82
kou
Drives: 08 lb
i am looking at 15''/7'' et38 should i get 205/50 or 195/55.
Old 01-21-2009, 09:41 PM   #83
kimona
kimona's Avatar
Are you lowered?
Old 01-21-2009, 09:41 PM   #84
kou
Drives: 08 lb
yes trd sportivo.thanks
Old 01-21-2009, 09:56 PM   #85
kimona
kimona's Avatar
Well, with 15x7, ET38, I would prefer to run 195mm rubber.
195/55/15 tyres sound like a good choice with your setup.
Old 01-21-2009, 09:59 PM   #86
kou
Drives: 08 lb
thank you i will start looking.
Old 01-21-2009, 10:04 PM   #87
Black Yaris
der Zeck
I like the updated guide Kimona!
Old 01-21-2009, 10:28 PM   #88
kimona
kimona's Avatar
Thanks. I did that a while back. Not complete yet. I'll get on it one of these days and finish it up.
Old 01-21-2009, 10:30 PM   #89
kimona
kimona's Avatar
You can find a bunch of tyre choices at this site: tires-easy.com
Sort by price, then click on shipping quote to find the real price. Shipping varies quite significantly by tyre.
Old 01-21-2009, 11:00 PM   #90
hafeez
thanks a lot kimona
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 Yesterday 01:51 PM
