#19 |
To each his own.
#20 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Yeah, I like the toyota washer, Good for 3 uses at least, but a buck? I am still on the original after 4 OC and time for new, We used spark plug washers in europe but no parts guy seems to carry anymore. Maybe with advent of $$$ iridium-tip sprak plug the replacement washer will come back. On the spark plug you shouls ALWAYS putting on the new crush-washer if you pull a plug. I see many Subaru's with toasted heads from backed out plugs and reused washers.
back into the oil pan = Guys, just do not substitute with a zinc-dipped steel in the vintertyme - it will dissapear (rusting) if you getting the salz-wasser on it! Sonja's bro |
#21 |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
here's a car ramp D.I.Y. ( for gear , motor oil change , etc. ) , go to http://s49.photobucket.com/albums/f2...t=IMG_1243.jpg . Could use 1 level for ramp instead of 2 ( plenty of clearance with 1 board ) . Then put 1 piece of wood across each end of board ( stoppers ) to prevent driving of ramp . Should take less than 1/2 an hour to cut and nail . This is from SCIONLIFE for an 1st generation XB , a cousin of the YARIS .
| What about the oil filter???? | Driver | DIY / Maintenance / Service | 28 | 10-23-2008 11:45 PM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
| Toyota oil filter difference in sizes? pics | Ogredude | DIY / Maintenance / Service | 7 | 04-02-2007 01:16 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
