![]() Drives: Vitz 2006 Join Date: Dec 2008
Battery Current Drain
I have a 2006 Vitz 1.0L Automatic.. Is it normal that when switched off ( even with the key taken out) it consumes 170mA??
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S Join Date: Oct 2008
Sounds normal to me. Batter has to be running to some of the electrical equipment. This is why you don't have to reset the clock every time you start up the car but do have to if you disconnect the battery. 170mA isn't a lot. My touchscreen cell phone uses about that much when I turn on the screen to check the time.
So this is not the case that i have a short or a leak somewhere!! this is normal!?!?!? has anybody checked, ever??
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Yes, that is a normal drain amount. I measured it while watching the effects of my solar trickle charger on the 12V battery.
Also keep in mind that even without any devices drawing current the battery still leaks some charge through gassing off. This is true for all rechargeable battery types but it is especially an issue with unsealed batteries. Most autos, including the Yaris, come with an unsealed battery (flooded lead acid).
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| battery power question | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 22 | 12-05-2008 08:37 PM |
| 6lb 6oz ultra light weight battery | heavystarch | Performance Modifications | 28 | 11-19-2008 06:02 PM |
| Where to get ring connector for positive battery terminal? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 11-13-2008 11:44 PM |
| battery relocation | redduck | Performance Modifications | 4 | 09-14-2007 07:53 PM |
