Reluctantly Crouched...
TRD Lowering Springs
SOLD!!!!
For sale is a slightly-used set of TRD lowering springs. I bought them from another YW user who had them installed for 4 months, then sold them to me (he went lower), and I installed them for 2 days, but had to pull them since my wheels rub up front when i corner hard. I have 215-40-17's w/ a +40 offset, so its just a bit too wide for these. The drop was perfect, and felt very nice. NOT a rough ride, and it hardly felt different from stock springs, other than a little better in the corners. I'm quite picky about keeping my car comfy and a daily driver, and these were great. Very bummed that my wheels aren't a good match. I did run them with the stock wheels/tires just to confirm that it was my wheels, and I had no rubbing, even when taking a freeway cloverleaf at 50 mph. $90 + shipping (should be under $20 in the lower 48.) Local pickup is free in DFW.
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2008
I'd be interested, but how much work are they to install? Can it be done with relatively basic tools?
Thanks |
wow great price!
can be swapped in a couple hours....a spring compressor is the only non-standard toolbox item
Yes, the tools you need are:
-Spring compressor ($20 @ Harbor Freight, $35 @ AutoZone, free to "loan" from most parts stores) -19mm, 17mm and 14mm sockets 17mm wrench (offset box wrench makes the strut tower bolts MUCH easier) 6mm allen wrench Jack and jack stands. I'm pretty sure that's it. There is a great DIY on this site, and I was able to install them in just over 3 hours the first time, 2 1/4 hours when I switched back to originals (solo!) I'm a pretty decent mechanic, but nothing beyond basic wrenching here. All the parts are easy to access and very easy to see. The only exception is that taking off the strut top bolts is a bit tedious, but actually very easy if you just take your time and use an offset box. I didn't remove the wipers and plastic shroud the second time, as the DIY suggests,and found it was no problem. Its the slowest part of the project with or without the shroud removed, but less than 10 minutes per side. The rears are so easy that you'll think you forgot something. Less than 30 minutes, even with a smoke break! If you can change brakes, you can do this. BTW - price is now $90+shipping. I wanna get me a sway bar! :) |
HISTORY REPEATED 11/04/08
I uninstalled my springs without the compressor. Wish you would of had these for sale before I bough my NF's. Anyway free bumb for a great price.
![]() ![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
if these are still around in a week or so I may be interested
Bump... still got em. Shipping will be $20 or less anywhere in the lower 48. I'll eat the difference if it's more.
#8 | |
that sound like a good deal
Sold!!
| what to look out for when installing lowering springs | songa | Performance Modifications | 34 | 09-15-2012 04:29 AM |
| tanabe nf210 vs. TRD lowering springs?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 01-24-2012 12:00 AM |
| TRD lowering springs' and/or shocks' Ride Quality?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-29-2006 01:42 PM |
| HOLEY COW 674.75 to install TRD lowering springs | dbaxter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-09-2006 01:40 PM |
| TRD Lowering Springs | DJ_Trizzak | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 07-06-2006 12:20 PM |
