![]() Drives: yaris 4dr sedan red Join Date: Nov 2008
Instrument cluster light
Hi I just installed 17inch rims to my yaris and after I installed them, a error message light up in the instrument cluster, the tire pressure check light went on. I wanna know if somebody else have the same problem? Help please
Did you move the tire pressure sensors from the old rims to the new ones?
where is that located?
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
the sensors are incorporated with your valve stem. I had this same problem when I put my rims on
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
do you mean i have to remove the tires of the rims, and remove the valve stems, and installed them to the aftermarket rims
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Yes or buy new sensors and have them placed on your new rims. If you had this service done at a tire shop, by law they are suppose to do this for you(if your Yaris was made after Sept 2007).
#7 | |
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
Yes thats why all 2008's have TPMS on them, no matter what the make is. Also thats why a lot of tire shops are starting to charge more if your car is an 08 or 09(at least in my area.)
![]() ![]() ![]() Drives: Flint Mica Sedan Join Date: Oct 2008
i have stock everything, and my light came on about 2-4 weeks after i bought it *new* i checked the tire pressure, and it's fine. anything else i can do? could take it to the dealer, but would rather not deal with the hassle.
Drives: yw calls me douche and racist. Join Date: Aug 2007
No.. really? I just thought it was only required by law to have the TPMS on the car from the factory.
Anything after isn't worth diddly. |
#11 | |
To do so: 1. Turn the iginition off 2. Connect the CG (pin 4) and TC (pin 13) pins together on the DLC3 connector (also known as the OBDII connector). You can do so with a small clip lead. ![]() 3. Turn the ignition on 4. TPWS light will light steady for three seconds 5. TPWS light will flash in a pattern indicating the stored DTCs (trouble codes). The pattern will require you to count the flashes and discern the delays between. For example, if DTCs 13 and 23 are stored you will see: 0.5 second flash 1.5 seconds off (1) 0.5 second flash 0.5 second flash 0.5 second flash (3) 2.5 seconds off (gap between stored codes) 0.5 second flash 0.5 second flash (2) 1.5 seconds off 0.5 second flash 0.5 second flash 0.5 second flash (3) 4.5 seconds off (gap between repeating) Then, it will start again and will repeat until you kill the iginition and remove the jumper. What the codes mean: 11, 12, 13 or 14 (Tire pressure low on one of the 4 tires) 21, 22 ,23 or 24 (No signal from one of the 4 sensors) 41, 42, 43, or 44 (Transmitter ID error on one of the 4 sensors) 65, 66 ,67, or 68 (Abnormal temperature inside one of the 4 tires) 71 (Transmitter ID not registered) 73 (Vehicle speed or Engine Speed Signal Malfunction) 76 (Malfunction in TPWS ECU internal cuircuit) 91 (Vehicle Speed Sensor Error) 94 (Engine Speed Sensor Error) |
Tire shops are required to make sure if they work on an 08 or 09 that they reset the TPMS or they could loose their certifications....but some smaller shops really dont get a damn.
#14 | |
![]() ![]() Drives: Hatch Join Date: May 2009
#15 |
That list is all of the codes. Because the Yaris does not register tires to specific corners, the 4 codes that all mean the same thing are due to the fact that it can be any one of the 4.
#16 | |
I jumpered my connector and I "think" it is giving me 34 and 39 (which may be meaningless because I initially had the jumper position reversed which reported nothing but a continuously flashing ABS light. THX! |
#17 | |
#18 |
I've searched some. Guess I'll need to keep searching. THX
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| 2007 yaris instrument cluster | rslyk | Willing to Buy by private party | 6 | 11-07-2008 01:41 PM |
| Instrument Cluster | Stoln | General Yaris / Vitz Discussion | 2 | 06-23-2007 01:43 AM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 10:22 AM |
