Old 12-12-2008, 08:15 PM   #1
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
Location of jack
I was planning on changing my exhaust, can anyone tell me where the jack is located in the car.... I looked for it everywhere in the boot, couldnt find it anywhere
Old 12-12-2008, 08:22 PM   #2
It's under the driver's seat. Check your manual for location and how to get it out. It can be a bit tricky.
Old 12-12-2008, 09:27 PM   #3
jinxor
jinxor's Avatar
thanks mate
Old 12-13-2008, 12:36 AM   #4
pretty sure the jack isnt supposed to be used except in emergencies....i was/am under the impression its only good for so many uses....
Old 12-13-2008, 11:41 AM   #5
b_hickman11
Drives: 08 Sedan
Its a jack......how does the jack know if its an emergency or not?
Old 12-13-2008, 12:15 PM   #6
1stToyota
1stToyota's Avatar
It's under the driver's seat. Move seat all the way forward to get a good look at it. And it's not a real great jack. I used mine once to put the spare on. I was on level ground and it didn't seem too stable. On a slope it'd probably start to bend like the one in my VW Golf did.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 12-13-2008, 01:56 PM   #7
voodoo22
Drives: Yaris Sedan (auto)
I've used the jack many times already to change and rotate tires.
It's a cheap jack, but it does the job and there's nothing wrong with using it frequently as long as you use safe procedures like you should with any jack.
voodoo22 is offline   Reply With Quote
Old 12-13-2008, 03:49 PM   #8
nemelek
DWEED
nemelek's Avatar
I don't know how many uses it has, however, it is the cheapest jack that I have ever used. I would never trust the jack enough to get under the car.
Old 12-13-2008, 04:26 PM   #9
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I am wondering where is the thing you use to turn the jack. Its not in the factory location like the manual says unless I am blind. I am getting tired of using the lug wrench.
Old 12-13-2008, 06:19 PM   #10
nemelek
DWEED
nemelek's Avatar
Yours might be missing. Mine was in the black box to the right of the spare tire.
Old 12-13-2008, 06:57 PM   #11
slvryaris
slvryaris's Avatar
Thanks nemelek.
Old 12-13-2008, 08:14 PM   #12
b_hickman11
Drives: 08 Sedan
What expensive OEM jacks have you used before? Please list make and model of car.
Old 12-14-2008, 02:27 AM   #13
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I used it once and I would agree that it sucks, on level ground I had to put so much force that the jack started to twist. It just dosn't seem to have the same mechanical advantage as the jack in my honda. Get a good floor jack and use stands if you are going under the car.
POORSHA is offline   Reply With Quote
Old 12-14-2008, 01:36 PM   #14
voodoo22
You should never get under any car only held up by a jack. That's what Jack stands are for.
Old 12-14-2008, 01:38 PM   #15
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Yeah it barely lifts the car barely lifting it at that... its creepy
Its a Chao!!!
Old 12-14-2008, 02:18 PM   #16
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
I've never attempted to use the OEM jack on this car. I use aluminum racing jacks.
3 pumps FTW, yO! :)
anonymous user is offline   Reply With Quote
Old 12-14-2008, 07:10 PM   #17
nemelek
DWEED
nemelek's Avatar
2004 Dodge Ram, 1988 Toyota Truck are two examples of jacks that exceeded the minimum requirement to lift the vehicle for a tire change.
Old 12-14-2008, 09:00 PM   #18
b_hickman11
Drives: 08 Sedan
If you noticed, my post said make and model of "CAR". Those 2 you listed are not cars.
Reinforce Jack points? Morgan DIY / Maintenance / Service 41 11-10-2015 07:31 AM
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 06:33 AM
Coud someone post pictures of the jack points on the Sedan & Hatch voodoo22 DIY / Maintenance / Service 4 11-08-2008 09:24 AM
diy factory aux location with aftermarked hu battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 0 10-28-2008 11:38 PM
Factory AUX Jack ojo In Car Entertainment + Electronics (audio / video / alarm) 1 06-06-2007 10:41 PM
