Old 12-18-2008, 07:40 AM   #1
mutatio
Drives: Flint Mica AT Sedan
Accelerator Problem
Started the Yaris today. It turned over but when I press the gas pedal no response from the engine. Any help, please? Possible fuses? Is my computer fried?
TIA. :-)
mutatio is offline   Reply With Quote
Old 12-18-2008, 09:09 AM   #2
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
In between the last time that you started the car successfully, and now, did you do anything to the car?
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 12-18-2008, 02:36 PM   #3
b_hickman11
Drives: 08 Sedan
Make sure there is nothing stuck under the gas pedal like the floor mat or a small puppy.
Old 12-18-2008, 02:42 PM   #4
ddongbap
Or a hickman.
Old 12-18-2008, 02:43 PM   #5
b_hickman11
Drives: 08 Sedan
Originally Posted by ddongbap View Post
Or a hickman.
Yea I hate when it flops out and get stuck up under there. The pain last for so long.
Old 12-18-2008, 02:44 PM   #6
ddongbap
I think they make creams for that.
Old 12-18-2008, 07:28 PM   #7
cleong
cleong's Avatar
Originally Posted by voodoo22 View Post
Which gear does the dash light indicator say you're in?
He said the engine turned over but it wouldn't start. If the car was in a gear other than P the starter motor wouldn't even work.
TRD Blue brake pads
DC Sports header
Old 12-18-2008, 08:04 PM   #8
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Wait so did it start and the pedal was unresponsive or it didnt start?
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 12-18-2008, 08:45 PM   #9
Forrest
Drives: 08 LB BLACK
He said, "Started the Yaris today. It turned over but when I press the gas pedal no response from the engine. "
Sounds like he means, car started but when he pushed the gas pedal, no rev from the engine. Atleast it sounds like he means that.
Forrest is offline   Reply With Quote
Old 12-18-2008, 10:11 PM   #10
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
if anything the pedal needs to be checked...as the actual pedal internals may have failed.....(drive by wire)
Old 12-19-2008, 11:23 AM   #11
Bullet120
Drives: 2007 Yaris Sedan
Sounds like a TPS-Throttle Position Sensor. Pretty common on drive by wire accelerators these days. If you had a scangauge, you could verify by seeing if your TPS reading changed when you step on it.
Generally its a whole pedal assemble replacement, not positive on the Yaris though.
Bullet120 is offline   Reply With Quote
Old 12-19-2008, 01:52 PM   #12
ddongbap
I think tinkerbell got stuck in the throttle body.
Old 12-19-2008, 01:53 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
what about N ?
Old 12-19-2008, 05:42 PM   #14
ddongbap
what about N ?
I remember when i busted my mom's van in to R at 60 mph. It just stalled out, as I popped it back into N. I popped it back into D, and it started up again.
So technically, D works too. LOL.
Old 12-19-2008, 08:24 PM   #15
cleong
cleong's Avatar
what about N ?
In most AT cars, it can only be started when the transmission is disengaged, ie the car won't start surging forward the moment you start the engine. As I never owned an AT Yaris I'm not in the best position to say if N would start the car, perhaps it would because the transmission is still disengaged.
When an MT Yaris requires the clutch to be depressed to the floor to engage the starter motor, I would be surprised that you could start an AT Yaris in gear, or even neutral for that matter.
TRD Blue brake pads
DC Sports header
Old 12-20-2008, 02:53 PM   #16
b_hickman11
Drives: 08 Sedan
How did this turn into a thread about starting when its really about the Accelerator?
Old 12-20-2008, 09:17 PM   #17
cleong
cleong's Avatar
I guess I'll say one more time that we can start our Yaris in N like I did in post 12. I'm sure we don't have some sort of mutant Yaris and that other AT owners can do the same.
You're probably right and I don't doubt you on that, I'm just saying that I'd be surprised.
TRD Blue brake pads
DC Sports header
