Old 12-21-2008, 07:37 PM   #1
JapRulezz
JapRulezz's Avatar
Drives: yaris sedan 2NZ-FE
a tyre question
if i were to replace my 185/60/r15 on my yaris with 195/55/r15 would that decrease the cars power ?
JapRulezz is offline   Reply With Quote
Old 12-21-2008, 07:56 PM   #2
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
nope. actually makes circumference of the tire smaller. thus less time for one rotation.
ztrack157 is offline   Reply With Quote
Old 12-21-2008, 07:56 PM   #3
no, no loss in power
Old 12-21-2008, 08:36 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
does that do anything to your gas mileage? Putting smaller tires on?
Theory tells me it would, but I dont know by how much.
ignore me please if this is a stupid question, lol
Old 12-21-2008, 08:49 PM   #5
would really affect economy....over size is pretty much the same....195-55 tire might be a bit heavier, but i wouldnt think itd be different enough to make any kind of a change except the wider rubber would grip better in handling...
Old 12-21-2008, 09:21 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
185/60/15 = 23.7
195/55/15 = 23.4
205/55/15 = 23.9
This information is in the "official wheel and tire guide" in the sticky in this section.
Old 12-22-2008, 01:29 AM   #7
ztrack157
ztrack157's Avatar
It would screw with your speedometer as well. Unless you hav a scangauge or something to correct it.
Old 12-22-2008, 04:14 AM   #8
ddongbap
MM.. I'm pretty sure a scangauge wouldn't fix that problem.
Old 12-22-2008, 07:12 PM   #9
JapRulezz
JapRulezz's Avatar
i did it people , and i feel a great deal more handling and stability , i asked the Question because although the less time for rotation , theres a increase in rubber width .... so who wins?
PS : i didnt understand that ''23.7'' thing by kimona
Old 12-22-2008, 09:04 PM   #10
YarisSedan
Drives: 08 Yaris Sedan
Your bottom end and off the line acceleration will benifit slightly. Your top speed will decrease as well as your top end fuel milage. Larger diamter will give you higher top speed and better economy on freeway speeds. If you do local driving and no more than 40mph then you will benifit from this. If you speed most of your time commuting you would be better off with a larger diamter size. Especially if you drive a automatic which is already geared twoards city driving.
Old 12-22-2008, 10:38 PM   #11
kimona
kimona's Avatar
Sorry. I was giving you diameter in inches so you could make a comparison among tyre sizes. The most common upgrade is from 185/60/15 to 205/55/15... because it is closest to OEM diameter.
Speedo error is not of concern with these tyre size changes. In fact, there is speedo error right out of the box with the Vitz/Yaris with OEM 14, 15, and 16 inch diameter wheels/tyres.
Old 12-23-2008, 11:27 AM   #12
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
No car has an accurate speedo and the faster you go the less accurate they are.
as long as someone doesn't go too crazy it wont be a "real" problem.
Russelt3hPirate is offline   Reply With Quote
Old 12-23-2008, 07:07 PM   #13
JapRulezz
JapRulezz's Avatar
just a second , forgive me for my car ignorance but how can 15' inch wheels have different diameters like 23.4 and 23.7 ? (doesn't 15 = diameter )
and how about filling the tyre with nitrogen instead of air which is better ?
Old 12-23-2008, 10:38 PM   #14
ddongbap
Its not the rims that make up different dia. Its the rubber size.
Old 12-24-2008, 12:38 PM   #15
nitrogen is a waste of money unless you track the car heavily
and cars have different rolling diameters and circumferences based on tire size.
205-55-15's are 205mm wide, the sidewall is 55% of the width (112.75mm) and the 15 is the wheel size. 195-55-15's are 195mm wide and the sidewall height is 55% of the width (107.25mm, in this case). 185-60-15's are 185mm wide, the width of the tire is 60% of the width (111mm) and the wheel is again a constant.
you want to land within 3% of your OEM rolling size to keep the speedo as accurate as possible...
1010tires.com had a great tire size calculator....
http://www.1010tires.com/TireSizeCalculator.asp
Old 12-24-2008, 01:41 PM   #16
b_hickman11
Drives: 08 Sedan
Some tires can be the same size but have a different total diameter. It depends on the tread depth. Some tires come with a 9/32 tread depth while some others might have 10/32 or 11/32. Some may be even more than that.
Old 12-24-2008, 04:50 PM   #17
Russelt3hPirate
l33t3st Asshole
Originally Posted by walri View Post
Go for helium, but remember that it is highly explosive (remember the Hindenberg).
wasn't the Hindenberg filled with Hydrogen?
Old 12-24-2008, 04:50 PM   #18
Tamago
Tamago's Avatar
Drives: ZZW30
i thought it was Centerlinium
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 01:38 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
this little thing cost me a new tyre spinejaruk General Yaris / Vitz Discussion 21 09-19-2007 10:26 AM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 11:27 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 06:44 PM
