Old 12-25-2008, 02:21 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Something aint right with the gas
Ever since the cold weather started my gas mpg has been about half of what i was getting in the summer, Summer i could get 125kms out of the first bar,now 125kms is taking 3 bars, a Tankfull in the summer was giving me close to 700kms now i'm hitting the last bar at 400kms
I never noticed that much of a winter mpg drop in any car i've owned over the 40+ years i've been driving,(conspiracy theory only)and am now starting to think the gas companies are putting something different in the gas so as to make for crappy gas mileage so we buy more and they make more money.
Old 12-25-2008, 03:17 AM   #2
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I noticed a drop in mine also, but I have been playing around with the intakes though, but they shouldnt make that big of a difference. It might be cause I am using my heater alot though.
slvryaris is offline   Reply With Quote
Old 12-25-2008, 05:21 AM   #3
nemelek
DWEED
nemelek's Avatar
I had a drop in milage also. It's not as cold here but the drop in tempature has made for longer warm up times. It's takes a lot more fuel to turn the gears when the transmission oil is -5 rather than 70 degrees. It might not help but try a bottle of "HEET" for your next fill up.
Old 12-25-2008, 09:00 AM   #4
SIPNGAS
I LOVE my Yaris!
SIPNGAS's Avatar
Drives: 2007 Polar White LB
I don't know about in Canada, but here in the winter they release the heavier, "winter weight" gasoline. I know exactly when that's in the tank because there is a marked drop in my gas mileage. Then, pair that up with longer warm ups, revving the engine if you get stuck or to get from a dead stop it really effects the mpgs.
Lisa
aka SIPNGAS
Old 12-25-2008, 12:59 PM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
remember defrost uses the A/C so all those times you use defrost you are chewing up something like 10-20% more power... thus gas will be burnt quicker.
My Mpg went from 43-44 down to 40. I have to use defrost now, and the temps are around 30-40F. The hit would've been worse, but I was running 32-35psi before, and am running 44psi now.
I'm hoping once spring comes that with the higher psi I'll finally be able to break 45mpg... I've come soooo close at 32psi.
Old 12-25-2008, 03:04 PM   #6
jambo101
jambo101's Avatar
I expect less than stellar mpg readings every winter but for some reason its worse this year. First couple of winters with my 01 Echo mpg went down to mid 30's but now the new Yaris and the old Echo are both struggling to make 30mpg something has changed.
Old 12-25-2008, 03:53 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
Same here. I get about 24mpg now. But thats cause im in heavy traffic now instead of my normal freeway commute. But id like to see atleast 30 still
Old 12-25-2008, 07:18 PM   #8
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Yep! The culprit is the "winter" formula gasoline.
aca72 is offline   Reply With Quote
Old 12-25-2008, 09:57 PM   #9
Kal-El
Kal-El's Avatar
Colder weather always affects gas mileage. The question is how much. Aside from the difference in gasoline, the engine simply runs less efficiently when it's cold. Plus, always running the heat must play a role.
Old 12-26-2008, 06:23 AM   #10
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
well mines ALWAYS gonna stay the same...
no winter here on GUAM....=(
would be nice though!
msfire671 is offline   Reply With Quote
Economics of Price Gouging and Gas shortages GeneW General Yaris / Vitz Discussion 1 10-31-2008 04:20 PM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 12:32 AM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
