![]() Drives: 2008 Yaris LB 1.5I 5MT Join Date: Sep 2007
Take the long way home on the highway or short trip home through city?
Hi. I am wondering what's best for my engine. Should I drive to work on the highway for 20 miles on way or take the 12 miles city trip. If I take the highway I have 5 stop light all the way. If I take the city I am constantly in stop and go traffic. what do u think?
engines, any and all of them, operate most efficiently and are less prone to failure and wear and tear when they run at one constant speed so long as said speed is within their operational limits. Changing speeds causes engines to deteriorate faster than if they do not have to change speeds. That being said, the highway trip will allow your engine to run at or near one speed for the duration of the trip while city driving will require your engine to almost constantly vary speed. Purely from a what's better for your engine standpoint, the highway, if its relatively unhilly is the better bet.
Which is more enjoyable?
Personally, I have several "detours" to avoid traffic and which are more pleasant. Sure, they add 10-15 miles to my commute; but with the great gas mileage of the Yaris it is no biggie. I hate rush-hour commuting and it is even worse when it rains; so I try to avoid it as much as possible. Plus, there is nothing better than being on a wide-open, scenic road with the window down and enjoying a good drive! Oh, and what Rich K said! Cheers! M2 |
Go highway. Better for the car, baetter for your sanity and actually probably safer too.
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
Definitely highway. Not only is it better for your engine as Rich pointed out, but it's better for just about ever other component of your car.
Most brake wear happens in the city. The city wears on your transmission far more than the constant highway gear. Even your suspension, tires, and steering components, all wear faster in city driving. Plus, your gas mileage is better (even considering the longer distance most of the time).
I am in a simular situation. I take the backroads to get home from work and avoid the freeway mainly because of traffic though. But in return i switched to amsoil synthetic oil. Which should help with engine protection a bit more.
Thank you :) I usually drive about 60 mph unless I am running late, If late then i usually drive 75 to 80. i drive a stick shift so it is alot of shifting in the city, the city is flat but the highway has couple of hills up and down going home up north. :)
It's alot of shifting in the city but 8 miles less :) in a one way drive. 20 m v.s. 12 m |
#8 | |
Thank you Guys, It's faster to take the highway. :)
| 90% on short trip. What to do to protect engine? | lh59 | DIY / Maintenance / Service | 22 | 12-17-2008 10:02 AM |
| Have you taken your Yaris on a long trip? Was it comfortable? | Yaris_Fan | General Yaris / Vitz Discussion | 22 | 07-17-2007 10:27 PM |
