Old 12-22-2008, 01:13 AM   #1
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Axle Back Question
Is the Axle back gonna give the car a lil extra umph or is it just for sound, because the factory piping will still be in place before that which is what 1.5 " or so. I"m just thinking about getting a generic muffler for now and save my money for when i replace from the headers on back with that nice magnaflow setup they have. i still have about a year and a half till i can yank off the header, tht's when my warrenty goes out.
Generic one i found. i know it'll need some custom work to install but shouldn't be more than a few bucks for the piping.
Dimension:
2.5" Inlet, 4" Tip, 18.5" Tip to Tip Long, 5.5" Width
Should give a deep tone.
Old 12-22-2008, 01:19 AM   #2
An axle-back is basically for sound and looks, I'm going to say you might get 1-2 whp, but others will have other opinions about this.
Old 12-22-2008, 01:27 AM   #3
_S7V7N_
_S7V7N_'s Avatar
That's what i figured, on another note the pipe from the axle back will have to be custom built cause they don't make an actual axle back " adapter " do they ?
Old 12-22-2008, 01:49 AM   #4
You can have a shop cut off the factory muffler and weld it on in its position.
Old 12-22-2008, 04:53 AM   #5
gwasabi
Drives: 07 Blazing Blue LB
when i put my greddy tic in i felt a little bit more back pressure. but it wasn't really THAT significant. Just a little nudge
gwasabi is offline   Reply With Quote
Old 12-22-2008, 05:21 AM   #6
Back pressure is a bad thing, better exhaust velocity is a good thing. I think you might have used the wrong term.
Old 12-22-2008, 11:45 AM   #7
_S7V7N_
_S7V7N_'s Avatar
cool deal thanks for the feedback guys.
Old 12-22-2008, 11:56 AM   #8
i think just a muffler would help open up the top end of the yaris powerband....ever see the oem muffler? its super restrictive
however, you will gain more power if you replace the piping from the resonator back...as the res is 2" thru and the piping beyond is 1.75"
imo, if youre just going to replace the axleback, you likley wouldnt see much of a difference between an axleback and just replacing the muffler...
Old 12-22-2008, 02:07 PM   #9
auxmike
auxmike's Avatar
Here's a vid of my TRD axelback in action. It's got a nice fat pipe going to the muffler straight out the box.....
No muss, no fuss. Two bolts and your golden.
Old 12-23-2008, 10:14 AM   #10
1nz
Drives: Vios
mine gained 4whp, cz when i took it of i only got 98hp, with free flow axle back i got 102.8whp
Please visit us @:
greddyvios.blogspot.com
1nz is offline   Reply With Quote
Old 12-27-2008, 12:39 AM   #11
mastaofdisasta
mastaofdisasta's Avatar
Drives: yaris
from what i heard...or rather what i was told is that backpressure can be a good thing and that engines do need a certain bit to perform optimally. Now dont quote me on this and i could be wrong...but going with larger exhaust on bigger v8 v6 engines is fine, or turboed supercharged engines, but on engines like ours, i think losing backpressure can actually be not good, therefore backpressure can be a good thing?
mastaofdisasta is offline   Reply With Quote
Old 12-27-2008, 09:26 AM   #12
naturally aspirated engines can still benefit from an increase in exhaust pipe diameter as they are typically made conservatively small from the factory. yaris is 1.75" stock and i cant see any problems w/ going up to 2"....2.25" might be ok too, but id lean towards 2", personally.
Old 12-30-2008, 12:15 AM   #13
Might be true, but a small increase in piping diameter should help rather than hinder the performance.
Old 12-30-2008, 10:04 AM   #14
Never Enough
Never Enough's Avatar
Drives: Jbody
agreed ^
Never Enough is offline   Reply With Quote
Old 01-18-2009, 12:22 AM   #15
Split
Drives: 2008 Yaris Sedan
Exclamation
dont put an exhaust on the yaris! if anything put on a nitto mid-pipe. when i had the nitto mid-pipe it actually made the car quieter and deeper. the only thing is it made it idle rough when holding the brake while in drive. this might not be a concern for standard transmission owners. the aftermarket exhausts sound kinda ricey except for maybe the vitz one and the trd ones. the nitto one i have is kinda ricey sounding, i think i'm going to add another resonator to quiet it down.
my is300 on the other hand... even with a complete straight pipe its deep! (watch in high quality)
http://www.youtube.com/watch?v=7D29N...e=channel_page
Split is offline   Reply With Quote
Old 01-18-2009, 12:38 AM   #16
ya, but thats 4cyl vs i-6...hard to compare tones
honestly, most 4 cyl engines w/ an exhaust sound similar....and would certainly sound ricey if youre used to a 6cyl's sound
Old 01-18-2009, 05:35 AM   #17
Split
Exclamation
generally true.. although boxer motors sound quiet different, and turbo 4cyl's. the wrx sti is ridiculously deep and throaty! the new 09 sentra se-r spec-v is an NA 2.5L i4 and its less ricey sounding too. The yaris doesnt sound bad at WOT, especially for a 1.5L.. and especially in car. I bet those tanabe's sound really good in cabin.
Old 01-20-2009, 01:23 AM   #18
My Magnaflow does not sound anywhere near ricey. It's nice and deep, a bit on the quiet side tho.
Looking for GTA HB to test Axle Back System RaptorRacing Canada 8 11-29-2008 12:14 AM
FS: Tanabe Concept G axle back exhaust yrsdrgn Items for Sale by private party 9 08-20-2007 05:33 AM
Harry Potter and the Thread of Spoilers Yaris Revenge Off-topic / Other Cars / Everything else Discussions 10 08-06-2007 10:03 AM
question about lb fold flat seats roxy84 General Yaris / Vitz Discussion 7 05-29-2007 02:07 PM
Why are there only axle back exhaust??? hatchbackkid82 Performance Modifications 11 04-30-2007 06:54 PM
