Old 12-30-2008, 07:54 PM   #1
Ton
Ton
Ton's Avatar
Drives: Yaris 08
Question about Sway Bar!
Hi,
Im triying to buy the sway bars for my car, but i dont know which brand is good or not? trd is a good one but maybe I can buy another one cheeper and better.
hope you guys can help me!
Gente latina, a ver si me dan una manito con esto del sway bar, cual me recomiendan y ya que la trd es bien costosa, se que hay tanto para adelante como para atras.
thanks.
Ton is offline   Reply With Quote
Old 12-30-2008, 07:59 PM   #2
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
Tanabe makes good bars as well. They also look nice
Old 12-30-2008, 08:22 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
For a rear sway bar, you can't go wrong with TRD.
Old 12-30-2008, 08:28 PM   #4
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
x2.
Old 12-31-2008, 08:48 PM   #5
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
trd is good, unless you want to manufacture your own bar.
anonymous user is offline   Reply With Quote
Old 12-31-2008, 08:50 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
TRD.........
Old 12-31-2008, 09:07 PM   #7
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I believe Tanabe makes a strut tower brace, not a sway bar...
Old 12-31-2008, 11:30 PM   #8
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
ULTRARACING also making sway bars for the Yaris( code UR-AR16-126 16mm) but the TRD bar is thicker so stiffer.
andries is offline   Reply With Quote
Old 01-01-2009, 01:28 AM   #9
josevenezolano
Drives: Toyota Yaris HB 2008
I have TRD one on my Car and I love it. Go ahead.
josevenezolano is offline   Reply With Quote
Old 01-01-2009, 07:01 AM   #10
Never Enough
Never Enough's Avatar
Drives: Jbody
All of these are great choices.
Never Enough is offline   Reply With Quote
Old 01-01-2009, 06:24 PM   #11
They also make a 19mm -- but the TRD is 22mm, and I would recommend it first.
Old 01-01-2009, 11:54 PM   #12
revoturbo
revoturbo's Avatar
Drives: yaris
for cornering 19mm - 22mm which the best for daily use? (not race)
Please send me the pict/ site of sway bar both TRD/ ultra racing
multimakmurperformance.com
revoturbo is offline   Reply With Quote
Old 01-02-2009, 02:11 AM   #13
carrera2
Drives: 2008 Toyota Yaris
if you fit a rear sway bar from TRD, do you need to upgrade the front bar as as well?
carrera2 is offline   Reply With Quote
Old 01-02-2009, 10:01 AM   #14
andries
aka Jack Wolfskin
Drives: Yaris
If you go to Google/Yahoo you can find it by yourself also
http://www.trdusa.com/
http://www.ultraracing.com.my/Catalog.asp
Old 01-02-2009, 12:06 PM   #15
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
trd all the way. the bar will not affect your cars daily driving, only spirited driving. the trd bar is perfect for stock or modified yarii. :)
Old 01-02-2009, 04:14 PM   #16
andries
aka Jack Wolfskin
Drives: Yaris
+1
Old 01-02-2009, 04:16 PM   #17
revoturbo
revoturbo's Avatar
Drives: yaris
Thanks..
Old 01-02-2009, 05:06 PM   #18
No, the rear bar helps correct the understeer the car was designed with. A front sway bar is not necessary, except possibly in a fully race-purposed version.
Sway bar opinions Nelson Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 12-10-2008 06:40 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
TRD rear sway bar chrisada_to2a Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 05-13-2007 04:43 PM
Sway Bar! dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 55 01-12-2007 03:31 AM
