Old 01-02-2009, 04:56 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Q about placement of wideband A/F sensor
I just wanted to get this straight in my head. The further back one places the wideband A/F sensor, in the exhaust system, the leaner it will show? i.e. most accurate is in the header, more lean after first cat, more lean after second cat.
The reason I ask is that when I dyno'd the car, the mechanic read the A/F mixture from the tailpipe. The entire A/F curve is probably shifted slightly to the lean side, right?
TIA
Old 01-02-2009, 05:10 PM   #2
I would think the tailpipe sensor has some way to compensate for the catalytic effect? Not really knowledgeable enough to give you an exact answer on that, but it does get a reading based on the oxygen amount in the exhaust, and that *should* be unaffected by the cats...
But if you're installing your own sensor, definitely get it as close to the header collector as possible
Old 01-02-2009, 05:42 PM   #3
richardholdener
Drives: 2008 Yaris hatch
The position of the oxygen sensor in the exhaust system will not change the reading (rich or lean). The farther away from the cylinder head, the air/fuel curve will have basically a time lag when compred to engine speed. This means that the curve will be the same with respect to rich or lean, it will be just shifted slightly in the rpm range. Once agin, no change in air/fuel reading from change in position of oxygen sensor or from having catalytic converter in system (seems odd but back to back tests reveal identical air/fuel before and after cat).
TIA
richardholdener is offline   Reply With Quote
Old 01-02-2009, 07:17 PM   #4
LtNoogie
LtNoogie's Avatar
Thanks Thomas and Richard.
Old 01-02-2009, 07:18 PM   #5
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I agree. I have seen slight variances at idle when taking AFR readings pre and post cat, but these seem to go away once the car is moving.
I've actually tested with 2 widebands at the same time.
Are you going to run a wideband in the car or do you just want a bung for testing?
Old 01-02-2009, 07:22 PM   #6
LtNoogie
LtNoogie's Avatar
I actually had a bung installed between the two cats for my wideband A/F. I was debating whether to spend the extra money to have the muffler shop drop the midpipe so that they could install another bung in the "correct" place in front of the first cat. If the meter is not going to show an appreciable difference, I'll start running the harness into the interior.
Old 01-02-2009, 07:37 PM   #7
largeorangefont
Break'em off some.
I actually had a bung installed between the two cats for my wideband A/F. I was debating whether to spend the extra money to have the muffler drop the midpipe so that they could install another bung in the "correct" place in front of the first cat. If the meter is not going to show an appreciable difference, I'll start running the harness into the interior.
Do you still have the stock cats? If so I would consider getting another bung up stream of the cats. If they are high flow aftermarket cats, don't worry about it.
In either case you will probably be OK. It is all relative anyway. No matter where you have the sensor mounted, if your readings change one day out of the blue, you will know something is amiss.
Old 01-04-2009, 09:28 PM   #8
GeneW
Drives: 2008 Yaris
I would put it before the Cat myself. The cat changes the chemistry of the mixture big time.
Gene
Old 03-04-2010, 09:06 AM   #9
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
I know this is old but I stumbled across this post in a google search and I feel obligated to post...this is plain false. The futher away from the motor (or conversely the closer to atmosphere you place) the o2 is the leaner it will show relative to another o2 placed further upstream in the exhaust system. Tailpipe sniffers on dyno's have free air going past them and will read leaner.
The Spectacle is offline   Reply With Quote
Old 03-04-2010, 09:55 AM   #10
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
the A/F sensor must be located in the raw exhaust stream before the first cat.
cat converters would render the readings meaningless
an O2 sensor is located after the cats to check for the efficiency of the cats themselves
127.0.0.1 is offline   Reply With Quote
Old 03-04-2010, 10:52 AM   #11
^ no, it's located between the two cats. So it can't be checking the second cat.
Old 03-04-2010, 11:46 AM   #12
127.0.0.1
EDIT: lawls...so wrong.
on these things it is between ? that's a new one on me
vehicles with 2 cats the a/f is always between engine and 1st cat
and the mid sensor is o2, which checks the cat 1 function, and the last
sensor is o2 also, also that checks the cat2 function. [almost no cars
have 3 sensors unless it multibank]
Old 03-04-2010, 11:08 PM   #13
127.0.0.1
http://etimago.com/yaris/repairmanua...%20Control.pdf
the air/fuel sensor is always *before* the cats as in all cars that use a/f sensors
the o2 sensor role (in cars the use a/f sensors) is to verify cat operations...and that is placed after a cat
in cars without a/f sensors, the front o2 sensor would be where the a/f sensor would be, and does
a similar job but with less accuracy. more like a rich/lean on/off switch than a linear response
Old 03-04-2010, 11:22 PM   #14
127.0.0.1
never put an engine controlling air/fuel sensor behind a cat. you do not want the computer running the engine based on reading from behind a cat.
Old 05-05-2012, 10:48 PM   #15
jaherrera1
Drives: Yaris Sport 2008
my english y bad.
My yaris (TOYOTA YARIS (NCP90L-AGMRK)) have code P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1). it has two oxygen sensors, which one should I replace according to the diagram below ...
http://www.toyodiy.com/parts/p_G_200...html?hl=89465A
which one is Bank 1 sensor 1... the part number 89465-52370 or 89465-52380 number
jaherrera1 is offline   Reply With Quote
Old 05-09-2012, 12:03 AM   #16
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Sensor 1 is the one closest to the engine, in the header.
Bad Air/ Fuel mixture sensor warning for ALL Yaris owners eric81 General Yaris / Vitz Discussion 31 04-21-2012 08:28 PM
Bad Speed Sensor? dmehak DIY / Maintenance / Service 33 01-05-2011 09:17 PM
lambda sensor hula hoop Willing to Buy by private party 1 11-24-2008 08:01 AM
FS: DC Sports Header + New A/F Sensor Return of the Yarii Items for Sale by private party 33 11-19-2008 09:18 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
