Old 01-07-2009, 05:12 PM   #1
andyanderso
Drives: 2007 Yaris Hatchback
Increased ground clearance?
I want to have more ground clearance on my Yaris. I have the 175/65 R14 wheels and tires on it right now.
My first thought is to get bigger tires - anyone know how big you can go and not hit anything?
second thought - a lift kit?? any ideas?
third thought - hydralics? yeah baby, yeah!
has anyone successfully done any of these things?
thanks for the advice.
andyanderso is offline   Reply With Quote
Old 01-07-2009, 05:14 PM   #2
Raising the center of gravity on such a short wheelbase is not something I would suggest, and ultimately that is what you are doing by raising the ground clearance. Why are you looking to raise the ground clearance.
Old 01-07-2009, 05:27 PM   #3
Benggolf2
Benggolf2's Avatar
Are you trying to make it look like a "monster truck"? (j/k)
Benggolf2
Old 01-07-2009, 05:48 PM   #4
nemelek
DWEED
nemelek's Avatar
With everyone trying to lower their car, you are probably the black sheep on this forum.
Old 01-07-2009, 05:59 PM   #5
jkuchta
Drives: 2007 Yaris hatch (red)
Gut the interior. I haven't changed out the OEM suspension yet, and my car is riding like an inch higher with all of the weight I've taken out of the car.
jkuchta is offline   Reply With Quote
Old 01-07-2009, 06:01 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
You can run 195/65/14's on your stock steel wheels without any worries.
Old 01-07-2009, 09:48 PM   #7
I believe there are rubber inserts that go in between the coils of the spring that'll raise the ride height a bit. It'll also increase the spring rate. However, I'm not sure how it'll handle during cross winds.
Old 01-07-2009, 11:46 PM   #8
andyanderso
It would be fun to have it look like a monster truck...hmmm some teeth painted on the side and big ole knobby tires...
anyway to respond to KCALB SIRAY -- I agree about the raised center of gravity. I only really want the clearance during the winter for driving through deep snow. I have to work early in the morning and the road isn't always plowed. So a temporary solution like bigger tires is probably what I am going to do.
Thanks kimona about the tire size...I figured I would definately be safe with 185/65/14 so it is good to know that I could go 195's. Do you know how much extra clearance this would give me?
I know everyone wants a lower car but somebody has to be that guy who wants something different right?
Thanks for all the help.
Old 01-08-2009, 01:02 AM   #9
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
175/65/14 = 23 inches diameter
185/65/14 = 23.5 inches
195/65/14 = 24 inches
Your car will be lifted by 1/2 the increase in diameter...
You could get a second set of wheels and mount 195/65/14 snow tires on them. This way you have the extra clearance only during the winter.
Old 01-08-2009, 01:27 AM   #10
True. You're that guy.
Old 01-08-2009, 07:45 AM   #11
kimona
kimona's Avatar
If you're going with snows on your OEM 14" steel wheels, then I'd recommend a 70 series tyre. You could go with 175/70/14 @ 23.7" or 185/70/14 @ 24.3".
Old 01-09-2009, 08:58 AM   #12
kimona
kimona's Avatar
Here's what you're looking for with increased ground clearance:
Old 01-09-2009, 01:05 PM   #13
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
My move was to narrower, deeper-section tires for snow, ie, 175s instead of 185s, and 70 rather than 65 section. If you can get 75s, better yet. The larger the diameter, the longer the contact patch. The narrower the tire, the more it cuts through, rather than ride up onto, the snow.
I don't drive my Yaris in the snow, I take the Volvo; much better. I just put a set of Tiger Paws on it, and they are MUCH better than the wide Yokohamas tht were on there, much better.
Old 01-09-2009, 01:29 PM   #14
MUSKOKA800
MUSKOKA800's Avatar
I'm thinking like-wise.
I'm TRD lowered and with the steelies and 175/65/14 winter tires (bought used) installed my sedan is very low. These winter tires stand about an inch lower than the stock summer set. My front lip spoilers is plowing when I'm in deep snow ruts.
I've researched a bit and found that 195/75/14 snows will stand at the exact height as the OEM rubber (185/60/15 stock on alloys) so next fall I may update my winter boots.
At least with the 195's I'll have the same ground clearance, instead of too-low for snow.
Old 01-09-2009, 02:15 PM   #15
kimona
kimona's Avatar
OEM 185/60/15 = 23.7", while 195/75/14 = 25.5"
For snows, you'd probably be best with 175/70/14 = 23.7", or 185/70/14 = 24.3"
Old 01-10-2009, 12:16 AM   #16
neo1985
neo1985's Avatar
Drives: yaris hb s
Send a message via MSN to neo1985
omg!! i saw it!! i was like.. u goin to rally? hehe.. but u told me u havnt change anything yet... lol like ur monitor system tho!!
neo1985 is offline   Reply With Quote
Old 03-06-2009, 07:35 PM   #17
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
My interest in raising would be to prevent underbody damage from rocks and uneven terrain. The trend to tiny wheels and minimal ground clearance in economy cars is definitely a bad thing for the car. The car makers seem to forget that many/most of the world's roads are unpaved, that speed bumps (speed mountains) are getting taller and more aggressive with all the trucks on the road, and there can be debris in the road at any time. A small wheelbase helps steer around the rocks and holes and over humps, but eventually you'll "thunk" stuff and scrape up your underbody badly. Even an inch can make a big difference.
bkrownd is offline   Reply With Quote
Old 03-06-2009, 10:56 PM   #18
TLyttle
TLyttle's Avatar
I understand your concern. I have already done in my rocker panels on snow humps; mind you, it would help if those panels were thicker than a Coors can... No damage on the underbody, yet.
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 12:08 PM
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
FREE GROUND SHIPPING TO YARISWORLD MEMBERS zetaproducts.net ZetaProducts.Net 10 12-05-2008 10:29 AM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 02:56 PM
Can you purchase the Ground Effects for S Sedan? formerechoowner Cosmetic Modifications (Exterior/Interior) 1 04-18-2007 11:15 PM
