#73 |
#74 |
![]() Drives: Yaris Join Date: Feb 2007
Damn those side markers look good. Nice and bright too, I likes..
#75 |
![]() Drives: 2007 Yaris Liftback RS Join Date: Apr 2006
Thanks Chris! This is now on the list of things to do!
#76 |
El Yoe
thank you so much for this, i have a white lb too, lol
Cuban to the bone, sitting in a Yaris, ahi si hay!!... |
#77 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
i have spiderlite... tail light led's i have the 3 arm x2's wedge brake ones that fit the stock socket and im using the 5 arm x2 with my aftermarket tails diff socket. been trying to get rid of my 3 arms... cant use them anymore
"It hurts more when its wet" |
#78 | |
#79 |
Slave To The Groove
Drives: 07 S Join Date: Aug 2007
Repeater Lamps
Has anyone installed them on a sadan?
#80 |
alright, another bump for the updated thread, since I sell these since those old days (smoked or clear):
#81 |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
Garm are these plug and play???
R-CaT Project Yar 2ZR |
#82 |
Side marker LED lights
I installed these and love 'em. Here's a few pics. The connector on the right is the connector on your smoked leds'. It needs to plug into the connector on the left which is from the wiring harness inside the fender well. You'll have to slightly modify your connector on the smoked led lights. I used a dremmel tool to cut away the shroud exposing the pins. and they plugged right in to the wiring harness connector. I used some electrical tape to hold them together. Remember there is polarity here.
#83 |
I just stripped the two wires, removed both harnesses, and taped it all together -- still working fine after a few months, only took 10 minutes per side.
#84 |
I'm still waiting for someone to install some BMW sidemarkers... a popular mod in Japan.
#85 |
that would be cool. I can also get Silvia side markers, which would rock!
#86 |
Yup, the Sylvia side markers would be very cool!
#87 |
can u get a part number on those side markers... thers a BMW dealer right around the corner from my pizza delivery job in maywood... MIGHT be able to get a discount on them
#88 |
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
Jerkratt, you should be the tester for those BMW side markers. It'd be perfect w/ your black setup ^_^. I'm waiting for those too.
#89 |
i printed out the picture of the markers... ima go there tomorrow cause its my day off and check it out
#90 |
I have a set here.. tried it years ago, and unless you flip them, and can cover some of the hole left behind in our stock fenders, "she no workie!"
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
| Smoke your own tail lights | ChinoCharles | Cosmetic Modifications (Exterior/Interior) | 9 | 01-15-2007 11:00 PM |
| xb side marker swap? | funkstrong | Cosmetic Modifications (Exterior/Interior) | 4 | 10-25-2006 11:32 AM |
| Fog Lights - only right hand side | JayCee | Cosmetic Modifications (Exterior/Interior) | 3 | 09-26-2006 05:44 PM |
| Side Turn Signal Lights | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 15 | 08-24-2006 06:06 PM |
