![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
How to change brake pads?
Is there a DIY on changing break pads front and back? also how to bleed the breaks?
http://www.yarisworld.com/forums/showthread.php?t=4530
Wow!! this is great thank you.
No problem-o, thats what we do.
There are numerous ways to "bleed brakes". You can do a google search and come up with them. Having just done mine I used them all, from pump in (Motive) to pump out (MityVac). The best results (for me) were obtained using the old fashioned 2 person method. Patience is a key word during this procedure.
I founf best results using a friend to help bleed the brakes as well. You might use a little more fluid, but it's worth the results.
You've gone through your brakes already??
![]() ![]() Drives: Sedan Join Date: Jan 2009
Don't bleed them unless you somehow open the system...
You need to open the system to change out the rear shoes, and cracking the bleeders on the front makes dropping in new pads much easier. I was changing the fluid out also, so it just made the whole operation much easier.
I didn't NEED to change pads and shoes, but wanted to when I took the car to the track. The front pads looked brand new after 35,XXX miles, and the rear shoes looked pretty much untouched too. As for changing out the rear shoes, the online manual that's sticky'ed above has the step-by-step, and it's relatively easy. The hard part is getting the main spring on and off. Other than that it's pretty straight forward. It took me an hour to do one side, and about 20 min. to do the other (first time I'd ever changed out drum shoes). |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Hey guys, what are you guys using as replacements? OEM from the dealor? Any aftermarket sources? I'm about due. At 25k, the right is squeaking. When I take the wheels off to inspect, I want to be able to do them if I see that I'll need to.
Having trouble with this old link.
![]() Drives: 2009 Yaris Hatchback Join Date: Mar 2011
I am also having problems with finding where this link has been moved to...
Link is forever gone. It might be posted on microimage forums.
I see. Thank you.
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads | ChinoCharles | DIY / Maintenance / Service | 40 | 10-13-2017 05:23 PM |
| ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS | kargoboy | YarisUniverse | 11 | 01-20-2009 04:43 PM |
| First thoughts: Carbotech XP8 pads and slotted rotors | jkuchta | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 12-19-2008 10:21 AM |
| ichi ban brake pads | Kitt | Central and South America | 13 | 10-30-2008 03:12 PM |
