Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 10-20-2008, 06:45 PM   #55
JStarkieUK
Drives: Toyota Yaris SR 1.8
Thank you very much I will take a look at the link!
Its a shame there are no bolt on kits available, at the end of the day, a turbo is a turbo! It shouldn't be that hard so why have none of the manufacturers made anything yet? They're missing out! Same for superchargers!
Thanks for the information buddy !
JStarkieUK is offline   Reply With Quote
Old 10-20-2008, 06:57 PM   #56
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
I agree with you... a turbo is no rocket science.
The problem I see is that the people who bought a Yaris did it mainly because of the fuel economy. There are some that put some money on normal bolt on performance parts such as CAI's, headers, exhaust.... etc
But when it comes the time to pay $$$ for a quality turbo kit... there aren't that many.
I have concidered a custom turbo set up, but as been discussed many times here... the tuning of these new Toyota ECU's is really tricky. Some people had been able to tune a Yaris but other have failed.
Since our engine was also released on the US this year on the Scion xD, the new 2009 Corolla and the New Matrix, I'm waiting to see if any options comes available for any of those cars.
Old 10-30-2008, 04:08 AM   #57
john21031
Drives: '10 Fit Sport MT and 2012 Fit
Originally Posted by jim TS View Post
did one of the yaris TS drivers tested there top speed???
i did!!!
THEIR top speed, not there...
john21031 is offline   Reply With Quote
Old 10-30-2008, 04:51 AM   #58
Rafterman
Drives: Yaris II TS 133 hp
hihi...yes i did
213 km/h or 132 mph on the navi
Rafterman is offline   Reply With Quote
Old 10-30-2008, 02:29 PM   #59
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Wouldn't someone have done a super or turbocharged 1ZZ-GE on a Celica or a Corolla?
EDIT: TTE seems to have done a supercharger for the Corolla TS.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 10-30-2008, 02:36 PM   #60
CASTREX
CASTREX's Avatar
Yeap, plenty of support for the old corolla TS. Including turbo kits and superchargers.
But our engine is not a 1zz nor a 2zz. Is the New 2ZR which is very different to the old zz engines.
Old 01-09-2009, 10:58 AM   #61
Yaris Palme
MAZDASPEED3
Yaris Palme's Avatar
Drives: MazdaSpeed3
Send a message via ICQ to Yaris Palme
NEWNEWNEWNEWNEWNEW
the shiftboot is black, it looks gray on the photo of my N95 8GB cellphonecam....
i will cut of the shiftboot asap.
Yaris Palme is offline   Reply With Quote
Old 01-09-2009, 11:48 AM   #62
CASTREX
CASTREX's Avatar
Nice looking. is that the TWM kit?
I used to have that one on my old Yaris.
The lower stick looks really nice altough in my case it was not very confortable because I needed to reach my arm too much to make shift.
Old 01-09-2009, 12:40 PM   #63
Yaris Palme
MAZDASPEED3
Drives: MazdaSpeed3
jeah, it´s the TMW kit. and yes it´s very low. But i hate the high look of the orig. shifter...... looks like in a rallyecar....
It´s a little bit harder to shift, but the way to shift is also very shorter. stupid lever principle..... ;)
Old 01-25-2009, 05:25 AM   #64
Yaris Palme
MAZDASPEED3
Drives: MazdaSpeed3
arrived on Friday
bought on USeBay
it isn´t a lot, but hmmmmmm it´s TRD ;)
it´s just for good looking.
yes i am crazy.....
Old 01-25-2009, 06:51 AM   #65
you will get used to it
Old 01-25-2009, 06:56 AM   #66
Yaris Palme
MAZDASPEED3
Drives: MazdaSpeed3
yes, now it´s very easy :D
Old 01-25-2009, 11:10 AM   #67
2DtheDon
Al-Madhi
2DtheDon's Avatar
Drives: Toyota Yaris Hatchback
Wooow lookes great ;)
2DtheDon is offline   Reply With Quote
Old 01-27-2009, 01:09 AM   #68
shtou
Drives: YARIS TS 1.8
so here is it.
my new yaris TSport with 98kW
and here is my subwoofer its just litte but with the 50Watt power it does work good.
http://farm1.static.flickr.com/229/5...2e261517_b.jpg
how much did you pay for it(subwoofer)?with all the cables you need
shtou is offline   Reply With Quote
Old 01-27-2009, 09:12 AM   #69
Yaris Palme
MAZDASPEED3
Drives: MazdaSpeed3
250euro incl fitting from the toyota dealer.
Old 01-28-2009, 01:46 AM   #70
shtou
here in romania ,they want 300E without installing..and everything is need for the installing operation..expensive
Old 01-28-2009, 03:22 AM   #71
Yaris Palme
MAZDASPEED3
Drives: MazdaSpeed3
i get it cheaper from my dealer, because it was the last sub.
Old 05-15-2009, 04:00 PM   #72
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
Originally Posted by CASTREX View Post
Yeap. Toyota numbers are really conservative.
First you got to see how heavy are the "bloody" rear seats...
I took them off and ride every day without them
For those fast runs I also took the spare tire, jack, tools and ran with very little fuel.
Now, for the Trc Off trick... Yes this car has no Trc off bottom so I just removed the TRC/VSC fuse out. It takes 5 seconds after you find it on the fuse box.
IMPORTANT...!!! By removing this fuse you will loose not only the Trc Control and the VSC but also the ABS.
I would not recommend this to anyone unless you are in a control environment ( Road Track) since the behavior of the car under extreme conditions will change.
By removing the fuse I was able to launch the car at higher rpm's and slip the tires a little bit without the car pushing the brakes by itself or cutting the power.
To put the car back to normal, just turn off the car, install the fuse back and re-start the engine. All functions should be back.
I'm currently looking for a way to install a switch within the cabin to disable these functions.
my car has neither traction control nor abs, it's all skill (angels & luck ;D)
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 10:18 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 09:01 PM
