Old 01-21-2009, 02:03 AM   #91
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Can you take a pic of, if possible? I might be able to work around it if the gap is just a streak on the upper top of bottom half of the bmw side marker...
Nonetheless, i'll see what Jerkratt comes up with~
Old 01-21-2009, 01:06 PM   #92
Rotorheader
Drives: 07 Yaris Hatchback
PM Sent
Rotorheader is offline   Reply With Quote
Old 01-21-2009, 02:13 PM   #93
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Originally Posted by bikegerm View Post
I installed these and love 'em. Here's a few pics. The connector on the right is the connector on your smoked leds'. It needs to plug into the connector on the left which is from the wiring harness inside the fender well. You'll have to slightly modify your connector on the smoked led lights. I used a dremmel tool to cut away the shroud exposing the pins. and they plugged right in to the wiring harness connector. I used some electrical tape to hold them together. Remember there is polarity here.
Are those the smoked or clear?? They look great!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-30-2009, 09:59 AM   #94
Jerkratt
Jerkratt's Avatar
ok i got a price... 20 bucks a piece.. looks like ALOT of beemers have them.. i gotta see if there all the same or if there differant in the back or not ima buy a pair most likely by the end of this week or next... and let u guys know. Kou what model bmw u get them off of?
"It hurts more when its wet"
Old 01-30-2009, 11:00 AM   #95
bxrich
bx in the house
Drives: toyota yaris sedan
anybody know the diameter of the hole 4 the side markers
bxrich is offline   Reply With Quote
Old 01-30-2009, 02:45 PM   #96
kou
Drives: 08 lb
i tried markers from a 2003 bmw3series they where to small.
Old 01-30-2009, 04:54 PM   #97
Jerkratt
Jerkratt's Avatar
ok ima try and see if all of them are the same.. i see the x3 has them aswell
Old 01-31-2009, 09:47 AM   #98
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
I just stripped the two wires, removed both harnesses, and taped it all together -- still working fine after a few months, only took 10 minutes per side.
Question why did you have to modify it??? mine was a simple plug and play??? Thanks anyway GARM!! Super fast shipping!
R-CaT
Project Yar 2ZR
Old 01-31-2009, 10:19 AM   #99
bxrich
bx in the house
anybody i'm going to them on my sedan but need the diameter of the hole to cut it out or can anybody trace the hole and send it to me
Old 01-31-2009, 10:31 AM   #100
MadMax
MadMax's Avatar
I just ordered a set from Garm, I so hate those cheap-o stock side markers and think the smoked ones from MicroImage will look so sweet on my Black Sand Pearl HB!
I'll post pics once I get them on!
Cheers! M2
Old 01-31-2009, 10:37 AM   #101
bxrich
bx in the house
Cheers! M2
got the same one's (microimage ftw)
Old 02-02-2009, 09:25 PM   #102
StefanVVTi
VVTi lover | D-4D driver
StefanVVTi's Avatar
Drives: 1.6 Corolla & 1.4 D-4D Yaris
Send a message via Yahoo to StefanVVTi
Can the white transparent plastic thing be removed from the housing and smoked?
(2006) - 1.6 VVTi Corolla & (2008) - 1.4 D-4D Yaris
StefanVVTi is offline   Reply With Quote
Old 02-04-2009, 11:01 PM   #103
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Keep us updated, I'm in w/ you if this can be worked around easily. Thanks
Old 02-05-2009, 09:11 AM   #104
Jerkratt
Jerkratt's Avatar
will do ill be picking them up sometime next week.. hours got cut at work so i dont have the money this week
Old 02-05-2009, 09:56 AM   #105
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
yea i feel you. I barely got 20 hours this week, had 8 hours to begin with :(
Side markers is my budget mod i can afford as of now~
Old 02-05-2009, 12:21 PM   #106
Jerkratt
Jerkratt's Avatar
well i see that the suv's have slightly fatter side markers then the normal cars.. so im going to go to the dealer and take mine out and size them... im going to measure the hole opening aswell and bring a ruler with me to the dealer so i can see if there will be a gap
Old 02-05-2009, 03:06 PM   #107
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Easier idea... pop out one of your side markers, hold a piece of paper on the side of your car, and trace the outline of the hole. It'll be easy to see if the BMW marker will cover it then.
2006 Red Blitzed RS 5-door
Old 02-05-2009, 06:03 PM   #108
Jerkratt
Jerkratt's Avatar
i went there today and got some part numbers... im going to go back next week and have them give me one of each and compair them.. the 3 series does not fit correct...
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
xb side marker swap? funkstrong Cosmetic Modifications (Exterior/Interior) 4 10-25-2006 11:32 AM
Fog Lights - only right hand side JayCee Cosmetic Modifications (Exterior/Interior) 3 09-26-2006 05:44 PM
