Old 01-14-2009, 02:08 AM   #1
phenoyz
phenoyz's Avatar
Drives: yaris
rim size
if u put 16 or 17 rims how much does it affect the gas mileage?
thx
phenoyz is offline   Reply With Quote
Old 01-21-2009, 10:29 AM   #2
REM
REM's Avatar
Drives: 2012 Nissan Leaf SL
I'm wondering the same thing. I always thought that the rim size didn't influence gas mileage, while circumference and weight of the wheel did. Am I wrong here?
Cheers,
Ryan
REM is offline   Reply With Quote
Old 01-21-2009, 08:14 PM   #3
depends on how much speeding up and slowing down you do...
if you do mostly highway, no difference at all
crandall has 17's w/ 215-40-17's and gets about 30miles(50km) less per tank than i get w/ 14's and 185-60-14's...and i do more in-city than he does
Old 01-21-2009, 08:26 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
all depends upon the weight.... my pink 17's were lighter than stock 15's
Old 01-22-2009, 06:59 PM   #5
smacky
Drives: 2008 Liftback AT
It also has to do with the width of the tire. Wider tires decrease your FE a bit.
smacky is offline   Reply With Quote
Old 01-30-2009, 05:53 PM   #6
SilverGlow
Drives: 2007 Yaris Hatchback
It's not just about weight. The bigger rims mean less torque. In othe words, LESS power at the driving wheels. City driving will suffer. Highway may not but I don't know for sure. The size of the rim, more then the weight, makes the most difference.
SilverGlow is offline   Reply With Quote
Old 01-30-2009, 09:44 PM   #7
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
Are you talking about the diameter of the tires? Or are you actually talking about the diameter of the rims?
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 02-10-2009, 03:11 PM   #8
Split
Drives: 2008 Yaris Sedan
lots of miss-information in this thread. some people don't seem to understand the simple concept, that when you run bigger rims, you run lower aspect ratio tires. the diameter stays the same, torque stays the same.
wide tires = loss of fuel economy
1) more weight (loss of FE when accelerating)
2) more rolling resistance (loss of FE at speed)
3) more drag / wind resistance (loss of FE at speed)
larger wheels generally weigh more, but (for example) SSR Type-C's in 18" are with light tires are still lighter than the stock 15"s, and will probably achieve better fuel economy.
that said, your tires will be like rubber bands and your wheels will be dented in no time!
Split is offline   Reply With Quote
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 05:15 PM
Opinion On Size Rims For Sedan? eii Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-18-2007 12:10 PM
Tire Size Sabretooth Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-09-2007 01:28 PM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 04:25 PM
Rim size difference???? marcus General Yaris / Vitz Discussion 2 11-03-2006 04:20 PM
