#73 | |
but to the OP, i can let you know the easy way to get rear camber.. if u so desire
#74 |
#75 |
now i gotta go find pix of the hoosiers on a yaris :D
#76 |
Top Notch!
#77 |
.058" stainless washers under the lower bolts between axle and hub. you'll have to grind them flat one side to clear the pilot hole. RusselTehPirate has them as well as the 10mm hub spacers i had fabbed awhile back
#78 |
Top Notch!
New wheels came in early! Ill be starting another thread for these.
#79 |
toyota
whats the spec on those.. is is 16's or 17's.. tire specs ??? model?? width?? i have so many questions?????????????????
#80 |
Top Notch!
#81 |
toyota
wow +15..
#82 |
![]() ![]() Drives: None. Join Date: Feb 2009
Looks good, it would look nicer lower for sure.
I digged the BBS RSs a bit more though. |
#83 |
![]() Drives: 08' Yaris RED Join Date: Feb 2009
is that a subaru badge in front?
ChinG |
#84 |
toyota
#85 |
Top Notch!
#86 |
Hrmm, i know RBwheels.com has some 16 in BBS RSs for cheaper than 2000. Ton of nice used wheels on that site.
#87 |
Top Notch!
#88 |
AKA Samurai Racer
how do you find acceleration compaired to a 17inch wheel? should be better?
#89 |
Top Notch!
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| MESH wheels under licence by BBS | kimona | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 09-10-2007 02:48 AM |
