Old 02-09-2009, 11:59 AM   #19
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Rev matching is matching the speed of the engine to the speed of the transmission thereby making the synchros have to do less work. When you're clutchless shifting, especially downshifting, it's nearly impossible to do smoothly without doing some rev-matching.
Best example is the first gear downshift that a lot of people think is difficult. It's difficult if you try to do it from too high of a speed and too quickly, but if you slow down to an appropriate speed for first gear and give the synchros time to work, it will slip right in. OR, you can do it quickly and smoothly at a somewhat higher speed (still needs to be a mid-range first gear speed!) by adding a little blip of the throttle as you depress the clutch to zing the revs up, thereby increasing the transmission input shaft speed and allowing the gears to easily mesh.
Works even better if you learn to "double-clutch". That is, to let the clutch back out while you're in neutral so that when you rev the engine, you're REALLY spinning up the transmission input shaft. Then clutching again, slipping the stick into gear and declutching again.
It all takes practice. Lots of practice. Don't force it, just let things happen. When you have the input shaft speed right for the gear you're trying to go into, it will slip right in.
It's a Zen thing.
Old 02-09-2009, 02:22 PM   #20
ztlonewolf
ztlonewolf's Avatar
Drives: 2008 red 3 dr S coupe
that right there is the key, with or with out clutch.. we're talkin tiny lil gears here people. if you can't revmatch on an up AND DOWN shift, you shouldn't be driving a manual trans IMO
the only time you may need to do revmatching on an upshift is if you shifted too slow,anymore than a 1000rpm drop between gears,you would have to rev the engine to match the roadspeed,or not be lazy and use the clutch
ztlonewolf is offline   Reply With Quote
Old 02-09-2009, 10:32 PM   #21
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
Darn... I was going to point out the double clutch, but you beat me to it! :-) I find that the Yaris really does prefer to be double clutched into first, even at slow speeds. Not sure why first is so picky compared to others cars I've driven.
twowheels is offline   Reply With Quote
Old 02-09-2009, 11:34 PM   #22
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Double Clutch? Hmmmmm?! This intresting very intresting I'm gonna try it. The first time I heard about it was in Fast and the Furios in the first race Vin Diesel said it " Not Double Clutching like you should" Lol I kinda liked that movie.
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 02-10-2009, 01:38 AM   #23
ddongbap
I do this all the time. Its sorta how a motorcycle tranny works. I mean the nonclutch part.
There are some sequential trannys that require a clutch for first gear, but every gear after that just requires the gear pull.
Old 02-10-2009, 01:39 AM   #24
Tamago
Tamago's Avatar
Drives: ZZW30
lol double clutching is for tractors and broken transmisssions
Old 02-10-2009, 01:40 AM   #25
Tamago
Tamago's Avatar
Drives: ZZW30
huh? i rev-match/heel-toe every downshift in my car.. it's a nice treat for your driveline to practice this.
Old 02-10-2009, 10:21 AM   #26
ztlonewolf
ztlonewolf's Avatar
revmatching is a must for downshifting,my post only refered to upshifting
Old 02-10-2009, 10:37 AM   #27
SeaYa
Is about to 'SeaYa' later
SeaYa's Avatar
Drives: 08 MT Sedan
OP: I agree 100% that you'll do little / no harm by shifting without the clutch if, like most of the above posts suggest, you rev match carefully. When I first read this, I thought it was rediculous, but then I thought about what was actually happening in the transmission, so, I held my breath and gave it a try from 3rd to 4th. AMAZING! Get the revs right, and the syncs almost guide your throw (more like a left-handed, underhand, one finger toss).
Hope you heal up well!
SeaYa is offline   Reply With Quote
Old 02-10-2009, 12:01 PM   #28
TheSilkySmooth
TheSilkySmooth's Avatar
If your not good at it would will put some x-tra wear on the blockers, and they are usually a soft metal alloy. Purpose bilt pedal setups are great for heel and toe - but I find most passenger cars are not set up well for that. Maybe porsche/vw with the bottom pivot go pedal ...
Old 02-10-2009, 12:03 PM   #29
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wait rev matching requires pressing the clutch aint it....so how can you rev match without pressing the clutch..do you just shift on certain rpm??
Old 02-10-2009, 12:03 PM   #30
TheSilkySmooth
It's a Zen thing.
Ohh, Loren TOOO sexy. I'm HOT now!
-Sis
Old 02-10-2009, 12:08 PM   #31
Loren
What?
Loren's Avatar
Do I need to put a parental advisory on such discussions? :)
You should hear me talk about driving smoothly at the limit, using a gentle touch with finesse to stay right on the edge without going past it.
Aren't cars fun?
Old 02-10-2009, 12:13 PM   #32
Loren
What?
Loren's Avatar
We've gotten a little off-topic talking about double-clutching.
The revs will pretty much take care of themselves on a clutchless upshift. Just takes patience and a gentle touch.
Where you've got to conciously "match revs" is on a clutchless downshift. You have to blip the throttle to get the revs up PAST where they need to be for the gear you're downshifting to, and then drop into the gear just as you would on an upshift.
Old 02-10-2009, 12:22 PM   #33
marcus
toyota
marcus's Avatar
cool although i have grinding gear phobia..i get spasm when i hear it..im not even joking.. just curious how it works...
Old 02-10-2009, 01:23 PM   #34
IllusionX
Drives: 07 Yaris Sedan Aero
i can't shift for shit with the yaris.
anyways, with a 93 civic, i was able to do exactly as loren suggests. I was able to upshift all the way to 5th and onto the highway, and downshift all the gears down to 2nd. (I didn't feel comfortable doing the 1st gear, but oh well!) not a single grinding gear.
There's a little timing to do for when you can pull out of gear without clutch. It has to be done without any pressure on the transmission. ie, not accelerating, nor decelerating.
marcus: it's pretty much impossible to grind gears when shifting without clutch. You cannot pull out of gear when there's pressure on the transmission. And when the rev do not match, the synchro would simply block you from shifting in anyways. When it's open, then the gears will slide in like warm butter.
Old 02-10-2009, 08:17 PM   #35
twowheels
You have to blip the throttle ***** to get the revs up PAST where they need to be for the gear you're downshifting to, and then drop into the gear just as you would on an upshift.
***** while in neutral
Old 02-10-2009, 08:19 PM   #36
TheSilkySmooth
A lot of people dont know that in a moderm synchromesh transmission, all gears are permanently engaged and you dont grind the gears at all. You are pushing a collar over a dog clutch that locks the idling gear to the mainshaft ; now the power goes down to the layshaft then back up to the final drive gear on the output shaft. Oh there must be a .GIF on the web somewhere ... Oh reverse is another story.
TWM Shift Knob SALE Until July 15th! TWM Performance Sponsors Classifieds Area 6 10-30-2009 01:46 PM
October sale on TWM Performance shift knobs! TWM Performance TWM Performance 1 10-31-2008 06:01 PM
Save $15 on all TWM Shift Knobs! TWM Performance Sponsors Classifieds Area 1 09-29-2007 01:04 AM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
Feb Shift Knob Sale From TWM! TWM Performance Sponsors Classifieds Area 2 02-18-2007 11:15 PM
