Old 02-14-2009, 01:55 PM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
The Big One upgrade
Here are some pics of my upgraded grounding system. Just used some 0 gauge from KnuKonceptz(Ultraflex) a little 3/4" heat shrink from Home depot and a 0 gauge ring terminal from KnuKonceptz. I also a negative battery terminal from them. Not much of a difference, just a bit smoother throttle response. It should make for better ground for the 3 amplifiers I will be installing.
Amazed at the poor quality of the grounding wire! I think anyone would benefit from a simple 6" add-on ground upgrade probably 4 gauge.
fuji is offline   Reply With Quote
Old 02-15-2009, 01:16 AM   #2
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
I will be doing this too! :) Thanks for the photos!
FEINT is offline   Reply With Quote
Old 02-15-2009, 03:37 AM   #3
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Another DIY Ground Wire option...
http://www.yarisworld.com/forums/showthread.php?t=2313
And stay grounded...
http://www.yarisworld.com/forums/sho...3&postcount=82
aca72 is offline   Reply With Quote
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
17" tires/wheels too big?? death is my gift Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 04-26-2007 11:39 PM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 02:44 PM
Big Brake kits for Yaris 5 door mojoyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 03-23-2007 01:30 AM
So how do you like the BIG SMILE on the 07 Sedan???? Ziv General Yaris / Vitz Discussion 3 02-03-2006 12:12 PM
