![]() Drives: 09 3dr,base,5sp,trd sway bar. Join Date: Feb 2009
195/55/15 OR 205/55/15?
will these fit on the stock steel wheels...with no rubbing?
any warranty issues when you change tire size? thanks.... going for a set of nokian wr. |
yes
no don't.. get a better tire than a nokian if you're gonna spend the money
No worries with 195/55/15 or 205/55/15 on stock steel wheels.
Check here for information about tyre sizing: http://www.yarisworld.com/forums/showthread.php?t=5021 |
205/55/15'S WILL RUB with stock wheels. not much but it does rub.
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
where specifically does it rub, and on what suspension?
im running tein's and it rubs on the lower fender well i believe. it usually happens when i turn wheel too far left or right like when making u-turn.....
SIPNDEW
i have 205/55/15 on my wheels lowered on df210s and it rubs at full lock and high speed (55+) dips
You'll get very minor rubbing lock-to-lock, which is pretty common on many set-ups with the Yaris. The good news is that we rarely lock-to-lock, and when we do, it's only briefly and at almost stop speeds. With 205/55's on stock suspension and wheels, there are no rubbing issues to worry about.
i have no problems at high speed just the LOCK TO LOCK as its refered.
#10 | |
SIPNDEW
the middle of the fender lip and the center of the front and rear splash guards. but i guess that depends on the wheels offset of they are aftermarket too, so stock would be different. like i said though, i have aftermarket 15s which are wider, not factory steel wheels.
SO, your saying it rubs on the REAR mudguard as well?
The rubbing is on the plastic fender liner and it is extremely minimal. It occurs only sometimes in a lock-to-lock maneuver and is nothing for concern.
#14 | |
. CLA 250, 4MATIC |
Actually, 205/50'a are not "mid point" but are shorter than both the tyres we're discussing. 205/50's work well on DF's, for example, but no need to run that short with stock suspension or a mild drop.
| 205/50/15 vs. 205/55/15: pics? | Thirty-Nine | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 07-14-2007 09:44 PM |
